According to sources online (eg HyperPhysics) the electric field strength around a point charge is $$E=k\frac{Q}{r^2}$$ This must means that the further you get away, the electric field should decrease with the square of the radius right?
But when these charges are placed into parallel plates somehow these will produce a uniform electric field? How I currently understand the physics can be summarized in the graph below of the electric field strength vs distance (Red and black lines are the electric field strengths of each plate and the blue is the resultant). enter image description here
It seems pretty clear this wouldn't be a uniform electric field. What happens such that the electric field strength is changed into a uniform field? I initially thought integration, but wouldn't that still give an inverse relationship?
In response to the proposed duplicate, my question is concerning 2 plates where as the other is about one plate (however, I can't really decipher what is being asked in the other question)
John Hon
  • 2,384
The intuitive answer is the following: When you have only one infinite plate the case is the same. If the plate is infinite in lenght, then "there is no spatial scale" in this problem (to an observer the plate looks the same from any height, the charge density does not change), there is no center and there is nothing (no physical features) that can tell you that you are closer or farther from the plate, any height would be the same. Of course you can measure the distance from the plate with a meter, but the point is that there is no features on the plate that will make one distance "different" that another. Now if you have two plates of oppossite charges it is the same, the field will be constant inside the plates and zero outside (as it cancels). This stops being true if the plates are finite, because now you have a scale: the size of the plate.
You have to remember that the electric field is a vector and not a scalar.
Let's consider a uniform electric charge on a infinite plane, and a point charge at height $h$ from it. Let's call the point directly below the point charge $P$.
The point charge gets attracted to every point on the plane, and the attractive force to a point on the plane at distance $r$ from $P$ is proportional to $$ \frac{1}{r^2+h^2} $$.
Now, the fraction of this force in the direction of the plane is proportional to a
$$ \frac{h}{\sqrt{r^2+h^2}} $$
fraction of the total force.
Thus, the force on the point charge in the direction of the plane is $$ \int_0^\infty \frac{h}{(r^2+h^2)^{3/2}}\, 2 \pi r \, dr $$
This integral doesn't depend on $h$. To see this, we can make the substitution $r = h s$. We get $$ \int_0^\infty \frac{h}{(h^2 s^2+h^2)^{3/2}} \,2 \pi h^2 s \, ds = \int_0^\infty \frac{1}{(s^2+1)^{3/2}} \,2 \pi s \, ds \, , $$ which is $2 \pi$.
So the attractive force on the point charge doesn't depend on its distance from the plane. Thus, the electric field must be constant.
Peter Shor
  • 11,536
If you place a uniform charge density, so not a single highly non-uniform point charge, on each of the plates, then far enough away from the edges of the plates the E field will be constant. Note that the plates should be much larger than their separation.
my2cts
  • 27,443
You're right !
This uniform field is only valid under certain approximations.
First the separation between plates must be very small compared to the size of the plates. This means that when we expand the exact solution in terms of powers $\frac x L$ where $x$ is the distance from plates and $L$ is a measure of the size of the plates, we can neglect anything but the constant term.
Typically we also assume an infinitely large plate, so that there are no boundary effects.
In a real situation, the edges ("boundary") clearly won't have the same field as the middle of the plate. So the field cannot be uniform for finite plates. Hence we approximate with infinite plates, which works well for the field in around the middle, and in the case of small separations this works well enough for most of the plate.
When you use separations comparable in magnitude to the size of the plates, you will not get a uniform field. It's easy to see that in that case the closer you are to one plate or another, the more influence it has on the field around you. In fact when the separation becomes much larger than the size f the plates, you can approximate the plates with points and you end up with an approximation of the field between two point charges, which is definitely not uniform.
