As some of you know, there is a fundamental flat space-time metric that describes our universe without any energy or matter in it. Correct me if I am wrong, but this metric and existance of the limiting speed of signal propagation which is not dependent of the observer are the same thing. Or? Could we understand one as a consequence of the other? So, could we say that the constant $c$ is a consequence of the metric? And, could there be some other, fundamentally different flat spacetime metric which allowes other forms of motion? Eg, greater speeds, in a nutshell, a different causality? What do you think, is there some more fundamental physical reality which determines the metric?
It doesn't matter whether the universe has matter in it or not. The metric is locally always Minkowski.
Given any metric whose eigenvalues have the signs $+---$, we can choose coordinates such that at a particular point, the form of the metric is $\operatorname{diag}(1,-1,-1,-1)$, which is the Minkowski form and which implies a speed $c$ (equal to 1 in these units) that all observers agree on. The set of signs is called the signature of the metric. So logically, there is a universal speed that arises because the metric has a particular signature.
And, could there be some other, fundamentaly different flat spacetime metric which allowes other forms of motion?
No, the canonical form described above applies to all metrics with this signature. Any variation in $c$ can be absorbed into the change of coordinates that brings the metric into the canonical form.
General relativity says that the metric is determined by the presence of mass-energy. What is physically observable about the metric is not $c$ or the signature, but the curvature.
The idea I think you're trying to get at is why a lot of people set $c=1$. As a sort of definition: as long as your pseudometric is (3,1) -- so, 3 space dimensions and 1 time -- and Riemannian, then you have an region locally looking like $\mathbb{R}^4$, and some cone of that space that has proper length of zero. The slope of that cone is then called $c$. But we could also just define our coordinate system locally to have that slope be $1$, and then you have the two coordinates on the same footing somewhat more equally.
In this sense, I guess you could say that $c$ is a consequence of the metric.
I don't think you can reasonably say that somewhere else a "different flat spacetime" could give "greater speeds". Speed is defined relative to that slope, of $c$. If you somehow rescaled spacetime so that $c$ was smaller, then all time would evolve slower, and the resulting physics would be the same.
The only way you can get different causal structure is on a larger scale (e.g. closed timelike curves), or a different local topology (at event horizons, extra time dimensions).
You seem to ask whether the laws of nature are governed by gravity, or vice versa. Spacetime existed at the big bang while one cannot speak of the big bang being a consequence of something else, since the big bang is the initial moment in time of our universe. So did gravity exist in its current form since the big bang, or were the fundamental constants of the universe determined shortly thereafter?
As for the cosmological constant: perhaps the nonzero vacuum energy density of spacetime acts as a limiting factor. We know for example that light travels slower in water than in air. Spacetime being a medium, might it have been "easier" to travel through with a smaller cosmological constant? This would make the cosmological constant more fundamental than the speed of light. In turn, the cosmological constant isn't even constant according to the theory of cosmic inflation.
To my knowledge it's unclear what the laws of physics were in the crazy energy regime of the big bang.
Geert VS
  • 121
Yes, the FRW-universe "without any energy or matter", often called the "empty universe", is mathematically equivalent to Minkowski spacetime by coordinate transformation which is globally flat. This means that special relativity holds throughout Minkowski space.
So, could we say that the constant c is a consequence of the metric?
No, the metric measures - sloppy said - lengths and angles - Whereas the lightspeed c is a universal physical constant which has the same value measured locally in flat or curved spacetime independent of the metric.
There are speculations that gravity could be an emergent phenomenon based on microscopic degrees of freedom. But if so that wouldn't affect general relativity and also not the FRW-metric.
timm
  • 1,607
