Imagine a practical way of doing this - sending the output of a laser into a Michelson interferometer and looking at the on-axis power along the various beam paths.
The "reconstructed beam" contains light from one beam that bounced off the partially silvered beam splitter, bounced off a (perfect) mirror then came straight through the beam splitter. The other beam has gone through the beam splitter, bounced off a mirror and then reflected from the beam splitter.
Each passage through the (perfect) beam splitter halves the power and hence divides the E-field amplitude by $\sqrt{2}$.
The combined beam is therefore the in-phase sum of two beams each with amplitude $E_0/2$, which gives a resultant wave carrying power proportional to $E^2$.
Problem solved? Not quite - you also have to follow what happened to the other recombined beam - the one that goes back towards the laser (note that with an appropriate mirror tilt, it doesn't have to go back exactly towards the laser). The two beams here have (i) gone straight through the beam splitter twice, with one reflection,or been reflected off the beam splitter twice with one reflection. The wrinkle here is that although the physical path difference along each "arm" is the same as for the usual "recombined" beam, there is an additional phase difference caused by the beam splitter.
In the case of the usual recombined beam we have one reflection from a glass-silver interface along one arm and one reflection from a air-silver interface along the other (because the silvering is only on one surface) - this introduced a $\pi$ phase shift between the arms which must be removed (by adjusting the arm length) to enable constructive interference.
For the beam going back towards the laser, the light along one arm suffers no reflections in the beam splitter and the other is reflected twice from the glass-silver interface and the net phase change is zero.
Thus if the arm length is adjusted to give constructive interference in the reconstructed beam, then there will be perfectly destructive interference (and hence zero power) in the beam going back towards the laser.
You cannot get constructive interference in one place without destructive interference in another. There is global energy conservation.
