I am confused about the following:
Mass is condensed energy. A photon has no mass, but it has a degree (of quantised) energy. Does that mean it does not have enough energy for it to be condensed enough to qualify as "mass"? If so, what is the (approximate) threshold?
Pregunto
  • 559
That is not correct. A lot of sources say things like that, but they are wrong.
Mass and energy are two separate properties that things can have, just like weight and volume and height. For ordinary objects in simple situations, mass $m$ and energy $E$ are related by the equation $$E^2 = m^2 c^4 + p^2 c^2$$ where $p$ is the object's momentum and $c$ is a unit conversion constant.
If the amount of energy an object has is $c$ times the amount of momentum it has, i.e. if $E = pc$, then the object has zero mass but still has energy. That's the case with photons, for example.
David Z
  • 77,804
Mass is, in a sense, interchangeable with energy, but the ways in which mass and energy can be interchanged are limited by the particular interactions allowed in the Standard Model.
First and foremost, all conservation laws must be obeyed. Since the photon carries no charges, this typically means that photons can only turn into matter-antimatter pairs, rather than, for example, isolated electrons. In addition, photons are spin-1 particles, and the conservation of angular momentum therefore forbids the creation of certain combinations of particles (for example, the photon cannot split into two spin-zero particles).
There are also other kinematic conservation laws (conservation of energy and momentum, for example) that must be obeyed. This means two things: first, the photon cannot create a set of products whose total mass is larger than the photon's energy. This is because the mass is the energy required to create these particles at rest, with any additional energy being manifested as kinetic energy of the products. As such, the total mass represents the minimum energy that a photon must have to produce a given set of products. Second, the conservation of linear momentum requires that a photon cannot produce matter spontaneously in a vacuum. Some interaction with another photon (in real life, this is typically a photon from the electromagnetic field around an atomic nucleus) is required in order to balance the momentum.
In addition, photons are excitations of the electromagnetic field; as such, they can only interact with particles with electric charge (or, with sufficient energy, composite particles made of charged constituents). In particular, this means that it is not possible* for a photon to turn into a neutrino-antineutrino pair, even though neutrinos have very small masses, because neutrinos are electrically neutral.
By far the most common mass-creation mechanism is the creation of an electron-positron pair (usually simply called pair production). This is by far the most common because electrons and positrons are the lightest charged particles in the Standard Model, and so represents the lowest energy threshold for mass creation. The electron mass is 511 keV, and so the threshold for electron-positron pair production is 1.022 MeV. This is a very high energy for a photon, placing it well into the gamma-ray range, and is not often found in terrestrial conditions. Pair-production processes for heavier particles exist, but the threshold energies are far higher, and producing or finding photons at these energies is difficult outside of particle accelerators or extreme astrophysical situations.
*When the words "not possible" are used in these discussions, they refer to processes evaluated in the low-energy regime of the theory, often called "tree-level" because the reaction diagrams (Feynman diagrams) are drawn as simple, tree-like structures. Allowing for more complicated diagrams opens up more possibilities (for example, photons can actually scatter off of each other in such diagrams), but such diagrams are only important at very high energies, much higher energies than most pair-production thresholds. As such, these more complicated diagrams are neglected here.
David Z is right to draw you attention to $E^2 = m^2 c^4 + p^2 c^2$. Here $m$ is rest mass, and a parcel of propagating electromagnetic radiation (whether in classical electromagnetism, or in quantum) has zero rest mass, and this does not prevent it from having kinetic energy. Nevertheless, the connection between mass and energy is close and profound. When hydrogens and neutrons fuse to make helium, for example, the rest mass of the product (helium nucleus) is smaller than the sum of the rest masses of the things that went in (two protons plus two neutrons), and the amount by which it is smaller is equal to the energy released divided by $c^2$. The same can be said of any chemical reaction, or any other process. Equally, if you want to generate stuff with greater rest mass than the stuff you started with, then it can be done by furnishing enough energy.
Andrew Steane
  • 65,285
photons aren't energy - for example, electrical energy does not consist of electrons, rather it's the density of charged particles creating a stronger electric field in a specific region doing work against a region of differing electric field. It would be the same with objects with mass (like atoms) - the binding fields at the nucleus of an atom give it mass, just as the fields around a photon do. You can annihilate an atom with antimatter, which allows the fields to collapse and create field waves which carry the energy - at the speed of light.
as a loose analogy, Wind in a sail does not push a boat forward - the pressure difference (field strength) on either side of the sail creates a force - so it's not the particles of air(photons) that push the boat(have mass), its the difference in air density(field strength).
Physics is not my strongpoint, so anyone please feel free to correct me!
