34
In the standard model of particles it is understood that besides characteristics like momentum, spin, etc., two electrons are indistinguishable.
Are two black holes, in the same sense, indistinguishable given they have the same mass, momentum, etc.?
Marco
  • 589
5 Answers5
42
The answer to this question is not technically known. The theorem that applies to this question is the "No-Hair Theorem" which states that a black hole is described by only 3 externally observable properties - mass, charge, and angular momentum - and that's it. The No Hair Theorem implies then that two black holes which have the same mass, charge, and angular momentum are identical to each other no matter the actual matter that was used to create them. E.g. if you create one black hole using a bunch of atoms vs you create another black hole using neutrinos only - the no hair theorem says as long as the two black holes end up with the same mass, charge, and angular momentum, one could not tell the two apart. One could not say which one was the one created by neutrinos and which one was the one created by ordinary atomic matter.
The problem though is that the No Hair theorem is not technically a theorem in that it hasn't been proven yet. It's more of a conjecture or hypothesis at this point. There are motivating factors which seem to imply the No Hair Theorem is true, but alas there is no clear proof using GR that it is.
enumaris
  • 4,154
17
To expand on the answer of enumaris, there are four types of black holes based on their mass, charge, and angular momentum. Uncharged non-rotating black holes are called Schwarzschild black holes. These can be different only by mass. Rotating uncharged black holes are called Kerr black holes. Charged non-rotating black holes are called Reissner-Nordstrom black holes. And finally rotating charged black holes are called Kerr-Newman black holes. The physics of different types of black holes is quite different. While all of them contain a singularity, they may have a different number of event horizons of different types and shapes. For example, a charged black hole has a Cauchy horizon inside the Schwarzschild horizon.
The no-hair conjecture was proven for the Schwarzschild black holes for the simplified case of the uniqueness in 1967. The result since has been expanded to charged and rotating black holes. The general uncharged case has been partially resolved under the additional hypothesis of non-degenerate event horizons and the assumption of real analyticity of the space-time continuum. However, there still is no rigorous proof of the general case.
safesphere
  • 13,017
10
Always be careful when your question involves gravity and quantum physics together. We have only very partial knowledge of that combination. In particular, note that the No Hair Theorem is a statement within classical general relativity, and as soon as you bring in quantum physics then things are complicated by the black hole entropy. As I understand it, this entropy is sufficiently well established that we would be very surprised if it turned out to be not there, and the place where it is found is on the horizon, and it typically has a large value. In this sense, black holes have a lot of "hair", i.e. physical properties that can distinguish one of them from another. The entropy is often huge: they have a huge amount of "hair", in the sense of available microstates consistent with their macrostate.
Andrew Steane
  • 65,285
I'm going to take a different approach to this :
Macroscopic vs. Quantum worlds.
In standard model of particles it is understood that besides characteristics like momentum, spin, etc two electrons are indistinguable.
Let's remember that an elementary particle is, by definition, identified by these characteristics. The (rest) mass is a fixed value. The spin is fixed, the various charge values are fixed. If they deviate from specific values then you do not have one of these particles at all.
But we say that two e.g. electrons are indistinguishable because in any system we cannot label them and track them in any way. We can make a measurement that says there is an electron at position one and two, but the instant we make those measurements we (in general) cease to know anything about the actual positions of the electrons.
We can't say that when we next measure those electron positions which electron is which - we can't track them. The electron at position one could be at position three or four next, and the electron that was at position two could now be at position three or four. We just know the next measurements produce two distinct measurements for positions of electrons.
Are in the same sense two black holes indistinguable given they have same mass, momentum, etc?
So not in the same sense as elementary particles.
If I have two black holes they have a macroscopic position. Unlike my electrons I can track them easily and there is no mystery between measurements as to which is which. Regardless of the no hair theorem, regardless of their size, rotation, charge, etc. they have distinct locations which can be tracked.
So the black hole that started at position one, I can say with essentially perfect confidence is the same one I measured at position three later. Likewise there's no confusion about whether the other black hole could be at position three and the one I thought was there is actually at position four.
So for macroscopic objects location is a property that labels them uniquely.
But for elementary particles this is not generally the case.
The No Hair Theorem
I think I should point out that the No Hair Theorem does not say we cannot distinguish black holes from each other, even if they are identical in external characteristics. It says that the only information we can determine about the black hole's interior (on the other side of that event horizon) are these "statistical" values.
-1
Maybe you can use the light bending properties of mass as hypothesized in general relativity and verified by experiment in 1918 - that gravity actually bends space. They did not look at a black hole, but rather a star, (maybe the sun, I don't remember), and the angular distortion created by the mass should make you able to calculate the mass, angular position and distance to object, and this mass you could calculate would make you able to distinguish black holes from less massive objects.
