-2
Newton's gravity equations give 5557 arc-sec/century Mercury perihelion advancement Vs 5600 arcsec/century actual observed. is it possible that regular asteroids striking force(radially inward due to Sun gravity) could explain the remaining 43 arcsecs/century discrepancy?
The perihelion advance of Mercury is rather small, but it was one of the very small number of things we could observe well enough a century or so ago to actually test GR.
Even if this advance could be explained within Newtonian gravitation by impacts on Mercury (I suspect it can't: other orbital parameters would change as well) you would need to account for its regularity: you need to account for $43''$ per century occurring as a tiny per-orbit change, So you'd need some stream of impacting objects hitting Mercury in some suitably asymmetric way, essentially all the time. Where are these objects? Presumably the impacts would be visible as they would, at least locally, cause significant heating: we don't observe this.
Apart from this, GR predicts much smaller rates of perihelion advance for other planets, notably Venus & Earth. These have now been measured and compared with the GR prediction (figures from Relativistic Perihelion Precession of Orbits of Venus and the Earth, Abhijit Biswas, Krishnan R. S. Mani, 2008):
$$ \begin{array}{rll} \text{Planet}&\text{Measured}&\text{Predicted by GR}\\ \text{Venus}&8.6247 \pm 0.0005&8.6247\\ \text{Earth}&3.8387 \pm 0.0004&3.8387 \end{array} $$
(Figures are seconds of arc / century.)
I think it's pretty convincing that the GR figures explain the results. It should also be convincing that Earth is not experiencing this strange rain of meteorites: we'd know if it was.
An alternative approach might be to look for other objects, preferably with much larger advances, and see if GR makes the right predictions for them as well.
And indeed we know of such objects. A famous example is the Hulse-Taylor binary. The Periastron advance of this system is about $4.2^\circ$ per year: the advance of this system in a day is about as much as Mercury's in a century.
Well, famously GR very nicely explains this and other characteristics of the orbit of the Hulse-Taylor system.
