According to "What is the net charge of the Earth?", the Earth is negatively charged, with a net charge of ${q}_{\small{\text{Earth}}} \approx - 5 \cdot {10}^{5} \, \mathrm{C} .$
Despite this negative charge, we still run grounding rods into the Earth to provide grounding for electrical devices.
$\hspace{225px}$
Question: How can electrical grounds function if the Earth already has a negative charge?
Nat
  • 4,720
When a conductor is grounded, its potential is equalized with the potential of the Earth and, provided that the grounding is adequate (low impedance), a large current can flow between the conductor and the ground without causing a significant potential difference between them.
This renders the conductor safe, which is the main point of the grounding.
The fact that both Earth and the grounded conductor have (the same) high potential relative to infinity or relative to the clouds or the ionosphere does not affect the effectiveness of the grounding.
V.F.
  • 12,353
The earth can be charged to any static voltage you want, positive or negative relative to outer space, and still be effective as a ground reference. This is because there is nowhere for that static bias voltage to flow to, which means it can serve perfectly well as a ground.
peterh
  • 8,872
niels nielsen
  • 99,024
