Put a cold rock of heat capacity $C_r$ and temperature $T_{r1}$ into an insulated fluid bath of finite heat capacity $C_b$ (the bath is not a reservoir) and temperature $T_{b1}$.
Now let the entire system come to internal thermal equilibrium, thus reaching state 2 with $T_2 = T_{r2} = T_{b2}$.
How do we find the entropy generated for this obviously irreversible process?
I started with the first law of thermodynamics on the whole system:
$$E_2 - E_1 = 0 = C_r(T_2 - T_{r1}) + C_b(T_2 - T_{b1}) $$
From which the final temperature is , $$T_2 = \frac{C_r T_{r1} + C_b T_{b1}}{C_r + C_b} $$
Now that we know the initial and final temperatures, the entropy change for the bath + rock can be calculated as:
$$ S_2 - S_1 = C_r \ln\left(\frac{T_2}{T_{r1}}\right) + C_b \ln\left(\frac{T_2}{T_{b1}} \right)$$
Now to get the entropy generated, we should find the entropy transfer so that we can apply the second law of thermodynamics:
$$ S_2 - S_1 = S_\text{transfer} + S_\text{generated} $$
But what exactly is the entropy transfer in this case? I'm confused because the heat transfer is not occurring over a constant temperature boundary, so we can't write $\mathrm dS = \frac{\delta Q}{T} $.
Thermodynamix
  • 1,802
  • 19
  • 32
Consider your rock as a closed system and the bath as the surroundings (or vice-versa). Together they can be considered as an isolated system. For such an isolated system the total entropy change would be zero if all processes were reversible. Any positive non-zero total entropy change would thus be considered entropy generated. Thus we can say that the entropy change of an isolated system formed by a closed system and its surroundings is given by
$$\Delta S_{isolated} = \Delta S_{sys} + \Delta S_{surr} = S_{gen}$$
For your example, if the heat transfers were reversible, you would have
$$S_2 – S_1 = 0$$
but since the transfers are irreversible you have
$$S_1 - S_2 =S_{gen} = C_r \ln\frac{T_2}{T_{r1}} + C_b \ln\frac{T_2}{T_{b1}}$$
Hope this helps
Themis
  • 5,951
Bob D
  • 81,786
