When bosonizing an interacting spinless Luttinger liquid, the action can be written as \begin{equation} S=\frac{K}{2\pi}\int dx d\tau\ (\partial_\mu\phi)^2 = \frac{1}{2\pi K}\int dx d\tau\ (\partial_\mu\theta)^2, \end{equation} where $$K=\sqrt{\frac{v_F+g_4/\pi+g_2/\pi}{v_F+g_4/\pi-g_2/\pi}}$$ is the Luttinger parameter, which is one for free fermions. The convention for the $\phi$ field is such that its compactification radius is $R=1$. Alternatively $K$ can be absorbed into the definition of the fields to change $R$ to $R=\sqrt{K}$.
The first equation has an superficial duality under $K\to 1/K$ and $\theta\to\phi$, and the free fermion case appears to be right on the self-dual point $K=1$ ($R=1$).
This duality looks very similar to the $T$-duality for a compact free boson CFT. In fact on page 157 of Fradkin's book (pdf available online), it was explicitly pointed out that "in string theory this transformation is known as T-duality and the Luttinger parameter is known as the compactification radius (see e.g. Polchinski (1998) and Di Francesco et al. (1997))."
However, in CFT it is well known that the $T$-duality takes $R\to 1/(2R)$ (or $K\to 1/(4K)$ using the convention above) and the self-dual point is $R^*=1/\sqrt{2}$, rather than $R=1$. Moreover, assuring this is not just a naive convention issue, there is an emergent $SU(2)\times SU(2)$ symmetry at this self-dual radius $R^*$, which is not the case for a free fermion theory.
So I am really confused whether the $K=1$ case is self-dual under $\theta\to\phi$, and if it is, whether it has anything to do with the $T$-duality. Is the statement in Fradkin's book quoted above wrong? What is the relation between this "$\theta$-$\phi$ duality" and $T$-duality?
pathintegral
  • 1,572
If you looks at this paper, figure 1: https://www.sciencedirect.com/science/article/pii/0550321388902490 you can clearly see that the self-dual point of the compact boson branch of the $c=1$ moduli space (which is $SU(2)_1$) at $R = 1/\sqrt{2}$ is not the free fermion CFT.
The free fermion CFT does not actually have the $\phi, \theta$ exchange symmetry because if treated properly (and using your normalization) these fields must have different periodicity. Indeed, one of them will have periodicity $4\pi$, say $\theta$, so that the fermion operator $e^{i \theta/2 + i \phi}$ is local. The duality exchanges which field gives rise to the fermion.
I also recommend you read I. Affleck's lectures from the 1988 Les Houches school on fields, strings, and critical phenomena (and all of the lectures contained inside). They are much more careful than the modern references.
Inspired by the answer by Ryan, I was able to work out the details identifying the $\theta$-$\phi$ duality as the $T$-duality.
Let us begin with \begin{align} S=\frac{1}{2\pi}\int dx d\tau\ (\partial_\mu \phi)^2, \end{align} where the compactification radius \begin{align}R_{\phi}=\sqrt{K}\end{align} and put it on a cylinder with circumference $L=1$.
We know that the spectrum for such a compactified boson is contributed by collective motions of the string and a sector of harmonic oscillations of the string. The equation of motion has (see Big Yellow Book) the following solution $\phi = \phi_0 + vt + 2\pi \sqrt{K}mx + \mathrm{oscillations}$, where $m\in\mathbb{Z}$ is a winding number around the cylinder. The speed $v$ is related to the canonical momentum $\Pi_{\phi}$, which is quantized as $\Pi_{\phi}=n/\sqrt{K},~n\in \mathbb{Z}$. Thus such a state is characterized by $(n,m)$, namely \begin{align} \phi = \phi_0 + \frac{n\pi t}{\sqrt{K}} + 2\pi \sqrt{K}mx + \mathrm{oscillations}. \end{align}
We can ask what primary fields creates this state. We know that the $(n,0)$ states, which are eigenstates of $\Pi_{\phi}$, is created by the vertex operator \begin{align} \mathcal{V}_{n}=e^{i{n}\phi/{\sqrt{K}}}, \end{align} but it is less obvious to find a field that creates a winding number $m$ in $\phi$. It turns out that it involves the dual field $\theta$ introduced in bosonization, with $S=\frac{1}{2\pi}\int dx d\tau \ (\partial_\mu\theta)^2$. We know from bosonization that $\theta$ and $\phi$ satisfy \begin{align} \partial_{t}\theta= -\partial_{x}\phi(=-2\pi \sqrt{K}m), \end{align} so $m$ is the actually the quantum number of the canonical momentum $\Pi_{\theta}= -2\sqrt{K} m$. The operator corresponding to $(n,m)$ state is thus \begin{align} \mathcal{V}_{(n,m)}=e^{i{n}\phi/{\sqrt{K}}+i2\sqrt{K}m\theta}. \end{align} We see that the compactification radius for the $\theta$ field is \begin{align} R_{\theta} = \frac{1}{2\sqrt{K}}. \end{align} The $n\to m$, $\theta\to\phi$, $K\to 1/(4K)$ symmetry of $\mathcal{V}_{(n,m)}$ is well known as the $T$-duality of the theory. The self-dual point is at $K=1/2$. At this point $R_{\phi}=R_{\theta}=1/\sqrt{2}$.
From this it is clear that the free Dirac fermion case with $K=1$ does not have the $\theta$-$\phi$ symmetry since their radii is different.
pathintegral
  • 1,572
