In the typical youtube animations/drawings of the electric and magnetic field fluctuations, the magnetic field peaks at the same time the electric field peaks. Since a magnetic field is created with a “changing” electric field, shouldnt the magnetic field peak when the electric field is changing most rapidly, namely, when the electric field is crossing from positive to negative? As the animations show, the magnetic field is peaked when the electric field is slowing to a stop then changing direction, and this doesnt seem correct to me. Are these animations just simplifying the actual dynamic?
Edit: so if dB/dt = dE/dt, a change in electric field causes a CHANGE in magnetic field? So when change of electric field is zero the change in magnetic field is zero?
