-2
A Dictionary of Physics (Oxford University Press) defines acceleration as:
The rate of increase of speed or velocity
However, from reading many other definitions it seems to me that acceleration in Physics is generally held to refer to the rate of increase of velocity (rather than speed), and that acceleration is generally held to be a vector quantity rather than scalar quantity.
How does this relate to the definition above of acceleration being able to be an increase in speed? What are the contexts in which acceleration is treated as an increase in speed? Do these tend to be more simplistic, less real-world treatments of acceleration or do they belong to another field such as Mathematics where the treatment may be more abstract and direction can be ignored?
I note that the SI unit for acceleration is metre per second squared (m/s2). Is it significant that this unit does not specify direction? Does this allow for accelertion to be a scalar or vector quantity depending on whether or not a direction is specified?
No. In physics there is only one official definition : acceleration is the rate of change of velocity. Like velocity it is a vector quantity which has both direction and magnitude. Acceleration includes change of direction as well as change of speed.
The distinction is important because the Laws of Physics are usually written as equations in terms of vector quantities wherever appropriate : for example $\mathbf{F}=m\mathbf{a}$. The scalar equation $F=ma$ ignores changes of direction when speed is constant, as in uniform circular motion. Vector equations are often more compact and enable a consistent sign convention to be applied. Equations written in terms of scalar magnitudes and angular directions are more complex and cause confusion when the sign convention changes to avoid negative values.
Sometimes the magnitude or the components of the acceleration vector are referred to as "acceleration" because it is more convenient, but this is not strictly correct. For example, centripetal acceleration in uniform circular motion is often described by its constant magnitude, because the varying direction (always toward the centre) is implied and does not often affect calculations.
The dictionary definition only mentions increase in velocity/speed. Probably it uses deceleration for decrease in speed but this distinction causes confusion. In 1D motion a -ve acceleration describes a slowing down and reversal of the motion of a particle travelling initially in the +x direction. Its deceleration (decrease of speed) changes to acceleration (increase of speed) although the applied force and its direction do not change.
sammy gerbil
  • 27,586
