This is a question about the frequencies that remain on the string during the decay of vibrations. As I understand it decay occurs because of the:
a- Internal damping of the string. This is due to the friction between material that make up the string).
b- External damping. This is due to vibrations that are absorbed by air.
c- Damping by the guitar body. This is the useful work. Vibrations that are transfered to the top.
Rate at which "c" occurs depends on the impedance matching between the string and the guitar body. My questions concern "c":
1- Does "c" get partly reversed by the elasticity of the top. Ie. are some frequencies returned to the string or even got canceled by the vibrating body depending on the phase of the returned vibrations?
2- Since impedance depends on the frequency, do some frequencies on the string get dampened faster than others?
3- What other factor would determine what frequencies present on the string during the decay?
Atilla
yes to 1, 2, and 3.
if the string frequency is close to a body resonance, energy gets fed back and forth between the string and the body.
the treble frequencies generally get damped faster than the bass frequencies do.
other factors determining which frequencies reside on the string are 1) whether the string was plucked with a stiff object or strummed with a soft one (hard pick strokes excite a set of higher harmonics, soft strumming does not) and 2) how fresh the strings are (old strings have more internal friction which attenuates the high frequencies before they have a chance to get radiated).
niels nielsen
  • 99,024
