A standard Toda field theory action will be of the shape:
$$ S_{\text{TFT}} = \int d^2 x~ \Bigg( \frac{1}{2} \langle\partial_\mu \phi, \partial^\mu \phi \rangle - \frac{m^2}{\beta^2} \sum_{i=1}^r n_i e^{\beta \langle\alpha_i, \phi\rangle} \Bigg)$$
Where r is the rank of the algebra with simple roots $\alpha_i$. Adding the affine extension to the algebra corresponds to adding an extra root $\alpha_0$, and I read everywhere (e.g. Mussardo's stat. field theory book, and this PhD thesis: https://arxiv.org/abs/hep-th/0008200) that while normal Toda field theories are conformally invariant, this added root destroys the invariance.
My first question is: How is the non-affine case a CFT? When expanding the exponential to look at the quadratic terms, we get a mass-squared operator $M^2_{ij}= m^2 \sum_{k=1}^r n_i (\alpha_k)^i (\alpha_k)^j$. I don't see why this apparently is always zero in the non-affine case.
Second question: How can I see that the extra root finally makes these masses nonzero.
Thanks!
