The impact of general relativity on an orbiting spacecraft can be seen according to modifications of Newtonian mechanics. It is not that hard to compute orbits in the Schwarzschild spacetime without pounding out Christoffel connection terms. The invariant interval $ds^2~=~g_{\mu\nu}dx^\mu dx^\nu$ has zero variation $\delta\int ds~=~0$. We can then see the action is equivalent to the proper time, and there is a Lagrangian ${\cal L}~=~ds/dt$ which has zero variation.
For the Schwarzschild metric
ds^2~=~c^2\left(1~-~\frac{2m}{r}\right)dt^2~-~\left(1~-~\frac{2m}{r}\right)^{-1}dr^2~-~r^2d\Omega^2,
for $m~=~GM/c^2$. We assume there is a weak field so $(1~-~\frac{2m}{r})^{-1}~\simeq$ $1~+~\frac{2m}{r}$ and we place the dynamics in a single plane so
ds^2~=~c^2\left(1~-~\frac{2m}{r}\right)dt^2~-~\left(1~+~\frac{2m}{r}\right)dr^2~-~r^2d\phi^2.
Now get the Lagrangian with
\left(\frac{ds}{dt}\right)^2~=~c^2\left(1~-~\frac{2m}{r}\right)~-~\left(1~+~\frac{2m}{r}\right)\left(\frac{dr}{dt}\right)^2~-~r^2\left(\frac{d\phi}{dt}^2\right)^2.
While this is the square of the Lagrangian, since the left hand side of the Euler-Lagrange equation has two derivatives there will be a term with $O(c^-1)$ from the derivative of the square root. This will be associated with a “square of the Lagrangian” in the denominator. This is the reason the $c^2$ term is kept on the $dt^2$ part of the line element. We drop this “square of the Lagrangian” in a semi-relativistic case. This means we can just use $\left(\frac{ds}{dt}\right)^2$ as the Lagrangian to $O(c^{-1})$ error. We then have the following differential equations
\frac{\partial}{\partial t}\left(\frac{\partial{\cal L}}{\partial\dot r}\right)~-~\left(\frac{\partial{\cal L}}{\partial r}\right)~=~0~\rightarrow~\ddot r~\simeq~\left(1~-~\frac{2GM}{rc^2}\right)\left[\left(1~-~\frac{v^2}{c^2}\right)\frac{GM}{r^2}~+~\frac{1}{2}r\dot\phi\right]
\frac{\partial}{\partial t}\left(\frac{\partial{\cal L}}{\partial\dot\phi}\right)~-~\left(\frac{\partial{\cal L}}{\partial\phi}\right)~=~0~\rightarrow~r^2\ddot\phi~+~-2r\dot r\dot\phi~=~0
These are the two relevant equations of motion
The first of these may be put in standard form with the angular momentum $L^2~=~m^2r^4\dot\phi^2$ so
\ddot r~=~\left(1~-~\frac{2GM}{rc^2}\right)\left[\left(1~-~\frac{v^2}{c^2}\right)\frac{GM}{r^2}~+~\frac{L^2}{2mr^3}\right].
Now with the elimination of the $O(c^{-2})$ terms we just have the standard Newtonian result for the force of gravitation. We then see there is the modification by the Lorentz factor $1~-~\frac{v^2}{c^2}$ and the Schwarzschild metric term $1~-~\frac{2GM}{rc^2}$.
For a spacecraft in Earth orbit with $v~=~\sqrt{GM/r}$ that $v/c~\simeq~2.3\times 10^{-5}$ and the relativistic correction terms are going to be on the order of $(v/c)^2~=~5\times 10^{-10}$. This appears small, until one considers navigation. This error is largely going to influence the relative rate that clocks tick. If in one second there is this error in timing of $5\times 10^{-10}sec$ this corresponds to a drift in distance error of $d~=~ct$ $=~16$cm. This suddenly becomes a considerable problem. For GPS tracking this is something of importance and knowledge of the gravitational field is a part of the geodesy of satellites.
