If there is an object which is $10 kg$, and we apply a force $|\vec F| = 100N$ then it will accelerate in the diraction where the force vector points with $10 m/s^2$
If the mass center is at point $O$ and the force is applied at point $P$, then the object will also have some radial acceleration $\tau=F|OP|$
What I do not understand, is that if all the force is converted to linear acceleration, then where does the radial acceleration come from?
Iter Ator
  • 317
Force is not a conserved quantity, but energy is. It must be that more energy is used when the force is applied off the center of mass rather than on it. However, this is curious. Suppose you have two thrusters on this spaceship opposite the center of mass. When you burn them, the ship won't move at all, nor rotate. So we must conclude that the energy from the thrusters is lost as heat. But now move each thruster to the left and right of the center of mass. If the ship has the right symmetry, it still won't gain any linear momentum, but it will rotate. That means some of the energy from the thrusters become rotational kinetic energy, while the remainder is lost as heat. Finally, point both thrusters in the same direction to one side of the center of mass, and the ship will move and rotate, so the energy from the thrusters becomes linear kinetic energy, rotational kinetic energy, and heat. So is the amount of heat dependent on where the thrusters are fired? I suppose so, but I'm not sure exactly how that works out.
HiddenBabel
  • 2,041
Force, linear acceleration, and linear momentum are all related to each other.
Torque, angular (rotary) acceleration and angular momentum are related to each other.
But the two groups are separate.
When you apply an unbalanced torque on an object, it'll change its rotation. That's about torque, not about the force(s) that make up that torque.
A force isn't "used up" when it's part of a torque and vice-versa. Force and torque are separate concepts, separate things.
Bob Jacobsen
  • 14,649
