Suppose two objects collide and combine into a single object, will the total relativistic momentum and relativistic mass stay the same? I read in my grade 12 physics text book that relativistic momentum can be defined as $|\text{relativistic momentum}| = \frac{\text{rest mass} \,\times\, v}{\sqrt{1 - \frac{v^2}{c^2}}}$ and relativistic mass can be defined as $\text{relativistic mass} = \frac{\text{rest mass}}{\sqrt{1 - \frac{v^2}{c^2}}}$. The total rest mass on the other hand doesn't necessarily have to stay the same. For example, the collision could heat up the combined system and the faster vibrating atoms could have stronger relativistic effects giving the combined system more inertia at the macroscopic level so we define it to have a higher rest mass.
Let's assume that any any frame of reference, two non-spinning object of any positive rest mass any subluminal velocity if they combine at such an angle that the combined system doesn't spin either, will always combine into an object with the same rest mass and velocity. Furthermore, let's assume that relativistic momentum and relativistic mass are a function of rest mass and subluminal velocity such that:
- For any subluminal velocity, relativistic momentum and relativistic mass vary linearly with rest mass.
- Relativistic momentum is in the direction of the velocity for nonzero subluminal velocity.
- Relativistic mass and magnitude of relativistic momentum don't vary between any two velocities with the same magnitude.
- The relativistic mass of an object at zero velocity is its rest mass and for any rest mass, as its velocity approaches zero, its relativistic momentum divided by its velocity approaches its rest mass.
- When ever two non-rotating objects combine into a single non-rotating object, the total relativistic mass and relativistic momentum are conserved.
After I did a lot of work, I figured out a mathematical proof in my head that in more than one dimension, the only solution to these criteria is:
- $\text{relativistic mass} = \frac{\text{rest mass}}{\sqrt{1 - \frac{v^2}{c^2}}}$ where $v$ is the speed of the object, not the velocity and $c$ is the speed of light.
- the relativistic momentum at zero velocity is zero and for nonzero subluminal velocity, the relativistic momentum is in the direction of the velocity and $|\text{relativistic momentum}| = \frac{\text{rest mass} \,\times\, v}{\sqrt{1 - \frac{v^2}{c^2}}}$
- For 2 nonrotating objects of any positive rest mass and subluminal velocity that combine into a single nonratating object, the rest mass and velocity of the system can be determined as follows: compute the relativistic mass and relativistic momentum of each object then add them to get the relativistic mass and relativistic momentum of the combined system then compute the rest mass and velocity of the combined system from its relativistic mass and relativistic momentum using the formulae for relativistic mass and relativistic momentum. Solving these equations, we get $\text{rest mass} = \sqrt{\text{relativistic mass}^2 - \frac{|\text{relativistic momentum}|}{c}^2}$ and $\text{velocity} = \frac{\text{relativistic momentum}}{\text{relativistic mass}}$ for nonzero relativistic momentum and $\text{rest mass} = \text{relativistic mass}$ for zero relativistic momentum.
How to we know the result I just proved as actually correct? I didn't prove that the original criteria I deduced this result from are correct. That problem can be solved by deciding that by definition, special relativity defines relativistic mass and relativistic momentum to follow the function they were shown to follow in the third last and second last bullet point and predicts that when ever two nonrotating objects combine into a single nonrotating object, the rest mass and velocity of the combined system actually is determined the way it is according to the last bullet point. Also using math, we can show that this prediction according to the theory is in fact a solution to the original criteria and it's actually easier to show that it is a solution than that only it can be a solution. I might not show a complete mathematical proof that it is a solution because it might be too confusing but I actually did figure out a mathemetical proof myself in my head that it is a solution also.
It's easy to show that in special relativity, subluminal velocities can be represented by points on a hyperbolic plane. Now if you have a Minkowski space and for an object of a given rest mass and any subluminal velocity, you plot a point in that Minkowski space where the time coordinate represents its relativistic mass and the spacial coordinates represent its relativistic momentum, you get a function from subluminal velocities to a plane in that Minkowski space that all have the same distance from the origin and therefore has hyperbolic geometry and each velocity exactly corresponds to the point in that hyperbolic plane that it represents as described earlier. From this, it's easy to show that in any frame of reference, two nonrotating objects of a given rest mass and velocity that combine into a nonrotating object will combine into an object of the same rest mass and velocity as they would in a stationary frame of reference.
Now in the real world, is it the case for any one specific material, the hotter it is, the more rest mass it has per atom and for a nonvibrating spinning object, its rest mass is defined as the triple integral of the relativistic density of each part in the frame of reference where the object has no overall movement and the relativistic density of each part is defined as $\text{relativistic density} = \frac{\text{rest density}}{\sqrt{1 - \frac{v^2}{c^2}}}$ and its relativistic mass in any frame of reference is defined the same way and it also turns out that even for a spinning object, $\text{relativistic mass} = \frac{\text{rest mass}}{\sqrt{1 - \frac{v^2}{c^2}}}$? Is it also the case that when ever two objects of a given rest mass and velocity if they combine whether or not they're spinning before or after the collision will always combine into an object of the rest mass and velocity predicted earlier regardless of the source of how much of its rest mass comes from thermal energy and how much of it comes from spinning kinetic energy? Maybe a quantum theory that doesn't include gravity can predict whether or not that's the case.
