As I was researching about how wifi works, I saw that wireless information exchange happens by using electro magnetic waves.
Also, the shorter the electro magnetic waves are, the less they can pass a material (like a wall). So senders with 5 GHz are not able to send as good as senders with 2.4 GHz through a wall.
And light is also an electro magnetic wave, right? So what would happen if the wavelength of it got doubled? or tripled?
Would light then be able to "go through a wall"?
watchme
  • 111
The electromagnetic spectrum is a continuum.
Look at the wavelengths in the table, when you double or triple you will end up on a different definition .Light is visual definition, and doubling wavelengths will take you to infrared, where all the heat is related and so not useful for carrying information as matter absorbs it fast. To be able to pass through walls you need huge factors to bring you to the giga herz region.
anna v
  • 236,935
