Even though $\Lambda$ isn't a tensor, you can still lower and raise indices with the metric. You are just multiplying matrices after all. They are useful because they let you express the inverse of $\Lambda$ in a convenient way. To be explicit, let's define "the" transformation matrices (the ones that transform vectors) with one index up and one down:
$$V'^\mu = \Lambda^\mu{}_\nu V^\nu.$$
A covariant vector transforms with the inverse:
$$A'_\mu = A_\nu (\Lambda^{-1})^\nu{}_\mu.$$
Note that $\Lambda^{-1}$ has the same index positioning as $\Lambda$, since the inverse of a linear transformation (which is what a 1-1 tensor is) is also a linear transformation. Now, one defining property of a Lorentz transformation is that $\eta_{\mu\nu} = \Lambda^\alpha{}_\mu \Lambda^\beta{}_\nu \eta_{\alpha\beta}$. Multiplying both sides by $\eta^\nu{}_\rho (\Lambda^{-1})^\mu{}_\lambda$, this is equivalent to
$$(\Lambda^{-1})^\rho{}_\lambda = \eta_{\lambda\beta} \eta^{\nu\rho} \Lambda^\beta{}_\nu = \Lambda_\lambda{}^\rho$$
which kind of says that $\Lambda^{-1} = \Lambda^T$ as long as you're careful with the index positioning. Indeed, this just says that the Lorentz matrices are orthogonal matrices with respect to the Minkowski inner product. It also lets us remember the covariant transformation law as
$$A'_\mu = \Lambda_\mu{}^\nu A_\nu$$
which is kind of like the contravariant version but with the indices reversed. I personally get confused, though, and prefer to not use any of this and just write $\Lambda^{-1}$ whenever I need to.
