Conservation of energy is, usually, a $\textbf{first order}$ non linear differential equation, generally written as
$$ \frac{m\dot{q}^2}{2} +V(q) = cte. $$
Taking the derivative yields the usual equation of motion.
$$ m\ddot{q} + V'(q) = 0 $$
(The $\dot{q}$ term vanishes.) Which is a $\textbf{second order}$ ODE. Since the non linear term $\dot{q}^2$ vanishes, this is easier to solve. There are hints for a kind of duality between first order and second order equations.
The same system could be described by Lagrange's equations
$$ \frac{d}{dt}\left(\frac{\partial L}{\partial\dot{x}}\right) = \frac{\partial L}{\partial x} $$
or Hamilton's equations,
$$ \frac{dp}{dt} = -\frac{\partial H}{\partial q}\quad ,\quad \frac{dq}{dt} =\frac{\partial H}{\partial p} $$
Again, there is the same hint about duality. Lagrange's equations are second order, and Hamilton's equations are first order. $\textbf{Is this the same duality as before?}$ Or is it a coincidence?
Conservation of a Hamiltonian is not a universal trait for a system. For this to occur the following must hold $$ \frac{\partial H}{\partial t} = 0 $$ otherwise it is not a constant of the motion. This is a manifestation of Noether's theorem.
The duality observed between Lagrange and Hamilton's equations follows from writing a second order system as a coupled first order system, through a Legendre transform.
Equations of motion must contain time derivatives in order to describe time evolution.
AngusTheMan
  • 2,581
  • 19
  • 33
