61
There exists this famous Haag's theorem which basically states that the interaction picture in QFT cannot exist. Yet, everyone uses it to calculate almost everything in QFT and it works beautifully.
  1. Why? More specifically to particle physics: In which limit does the LSZ formula work?
  2. Can someone give me an example of a QFT calculation (of something measurable in current experiments, something really practical!) in which the interaction picture fails miserably due to Haag's theorem?
Rafael
  • 2,771
6 Answers6
21
every theorem is only as powerful as its assumptions (and propositions). The answers are clearly that
  1. The LSZ formula always works for the field theories where it's used.
  2. No actual calculation relevant to physics fails because of Haag's theorem. Haag's theorem is just a philosophy.
Haag's theorem is morally wrong because it studies the question whether the operators in the interacting theory are "strictly" unitarily equivalent to those in the free theory: $$O_\mathrm{interacting} = U O_\mathrm{free} U^{-1}$$ Not surprisingly, Haag finds out that such a unitary equivalence doesn't exist. This is not surprising because, as we know, operators acquire anomalous dimensions from the interactions (and quantum effects), among other deviations from the classical intuition, and the naive algebra that is valid in the free theory simply no longer applies to the interacting theory.
In particular, the addition of the interactions also modifies the commutation relations between the fields that "directly" create and annihilate the particles - at least the low-energy effective fields. For example, the quantum effects produce effective Lagrangians that contain higher-derivative terms, including new terms with time-derivatives, and the latter modify the canonical momenta and/or the canonical commutation relations. When one is rigorous, many things change when the interactions are added. Haag only assumed that "some" things change, so his results are inconsequential for physics.
At any rate, this 1955 theorem is obsolete - much like most of the former discipline that used to be known as algebraic quantum field theory or axiomatic field theory - and be sure that interacting quantum field theories exist - lattice QCD is an example of a specific way how to define them - and it is equally true that the perturbative approximation of all the physical amplitudes may be calculated by the usual perturbative methods, with the extra philosophy and rigorous refinements given e.g. by the LSZ formalism you mentioned.
Haag's theorem was invented as an attempt to show that there was something wrong with one of the first loop diagrams people understood - the vacuum polarization graph. Mr Haag didn't like them. However, there is nothing wrong with the loop diagram - or any other loop diagrams that became the bulk of knowledge about particle physics in the subsequent decades. The developments in renormalization showed that the calculations, including the loops, are totally valid. The renormalization group made some further progress - it explained why the theories are universal and why the subtraction of infinities work. Haag's theorem became misleading and obsolete in the 1970s.
In particular, the LSZ formalism uses the "adiabatic hypothesis", the assumption that one may neglect the interactions between the particles in the asymptotically distant past. By slowly and continuously turning on the coupling constant, we may map the states of free particles to the states describing particles in the interacting Hilbert space. This is possible as long as all distances between the particles are large. However, this procedure wouldn't work for general configurations of nearby particles - so one can't promote this trick into a full-fledged "canonical" unitary equivalence between the free and interacting Hilbert spaces. There is clearly no such a "natural" or "unique" or "canonical" isomorphism because the free and interacting theories are physically inequivalent. When understood rationally, Haag's theorem is not saying anything else than this self-evident proposition. However, such an isomorphism is not needed to calculate physically meaningful quantities such as the scattering amplitudes.
At least from the viewpoint of physics as an empirical science, it should be clear that the actual calculations in QFT are good science - one that has made predictions and has passed tests comparing the predictions with experiments - while Haag's theorem is not because it hasn't predicted anything that has passed empirical tests. Haag's theorem tries to find problems with the fact that quantum field theory contains new effects such as renormalization that don't appear in quantum mechanics with a finite number of degrees of freedom. However, these extra effects of quantum field theory are real and essential and they lead to no inconsistencies.
Haag's theorem is not a tool to do particle physics; it's an excuse for someone who doesn't want to study particle physics. As every theorem, it says "A implies B". Because we know that B is incorrect - perturbative QFT clearly works - it follows that the assumptions A aren't right.
Luboš Motl
  • 182,599
17
A comment on what Lubos wrote (it would seem that I need more reputation to post comments :-)
There are still people who are living and are doing research in AQFT, so maybe AQFT is obsolete for some of us, but it is not dead.
We still don't have a full mathematically rigorous understanding of QFT. But everybody is allowed to ignore this, of course, and use the computational tools of QFT that have proven their value. Haag's theorem tells us that we simply don't know why the computational tools of perturbative QFT work so well, but as far as concrete computations go, as long as you get the numbers right, this does not need to concern you. Therefore you won't find any calculations that did not work out because of Haag's theorem.
Any rigorous construction of an interacting 4D QFT will have to avoid Haag's theorem in one way or another, however. But if the endeavor to do research into this direction is worth the effort is of course a matter of discretion.
Tim van Beek
  • 3,755
12
Much has been said… but I think there's a crack that I can poke.
References
First off, let me list a few of the relevant references for this topic: this way we can set the basis of the discussion and agree on a certain 'common theme of knowledge' (I understand there may be dissent and disagreement on the choice given below, but I believe that the historical relevance of the works is self-evident — this list is by no means exhaustive, and I mean no disrespect for works I may have forgotten to list). There it goes,
  1. PCT, Spin and Statistics, and All That;
  2. Local Quantum Physics: Fields, Particles, Algebras (Theoretical and Mathematical Physics);
  3. Mathematical Theory of Quantum Fields (International Series of Monographs on Physics);
  4. Finite Quantum Electrodynamics;
  5. Perturbative Quantum Electrodynamics and Axiomatic Field Theory (Theoretical and Mathematical Physics);
  6. Quantum Field Theory I: Basics in Mathematics and Physics: A Bridge between Mathematicians and Physicists (v. 1), and Quantum Field Theory II: Quantum Electrodynamics: A Bridge between Mathematicians and Physicists;
  7. Quantum Field Theory (Mathematical Surveys and Monographs);
  8. Mathematical Aspects of Quantum Field Theory (Cambridge Studies in Advanced Mathematics);
  9. Quantum Field Theory for Mathematicians (Encyclopedia of Mathematics and its Applications);
  10. Mathematical Theory of Feynman Path Integrals: An Introduction (Lecture Notes in Mathematics), and White Noise Calculus and Fock Space (Lecture Notes in Mathematics).
Comments
With that out of the way, let me make some comments. With a bit of luck I won't digress too much to the point of losing the original path…
  1. Historically, there were two movements with separate names: Axiomatic (or Algebraic) Quantum Field Theory, and Constructive Quantum Field Theory. While the former is marked by the reference (1) above, the latter is summarized in Quantum Physics: A Functional Integral Point of View. Both of them faced similar obstacles during their times: the first incarnation of Wightman's Axioms did not allow for [spontaneous] symmetry breaking (a fact later corrected by Ray Streater); while Glimm & Jaffe's book still insists that a [Feynman] Path Integral is associated to a unique quantum theory (something we know not to be true based on the Path Integral's dependence on its parameters (aka, coupling constants): different sets of parameters yield distinct QFTs). In fact, this is the very reason why I did not mix these topics (Algebraic and Constructive QFTs) in the list of refs above.
  2. Haag's Theorem (and also Haag-Kastler's theorem), historically, belongs to the field of Algebraic/Axiomatic QFT. But, later, with the further developments lead by Haag and his followers, this field naturally evolved into what is presently known as Local Quantum Physics.
  3. There are ways to rigorously define Euclidean QFTs in the lattice and then take its continuum (thermodynamic) limit. But, of course, I can't remember (or retrieve from my archives) the reference. IIRC, it was a group from Boston University… but, more importantly, I know who will be able to remember this: Pedro (lqpman ;-). In any case, B. Simon has a bunch of work done in this area (namely $P(\phi)_2$ Euclidean QFT and its relation to Statistical Mechanics), and it's not difficult to convince oneself that rigorous QFTs can be defined appropriately (in different ways, using different techniques).
  4. There are several ways to think of a QFT (or Gauge Theory, as you wish) and, as such, to formulate it in a variety of rigorous ways. Let me present one which I think is somewhat intuitive and more straightforward. In every single 'real life scenario' you have a maximum available energy, i.e., a UV-cutoff (call it $\Lambda$). With this simple realization you can start to construct your ingredients more rigorously: cast your QFT in a lattice where the spacing is given by $a = 1/\Lambda$. What I'm saying is that, in 'real life', we're always dealing with an Effective Field Theory of a form or another — and this is not altogether bad, for we can use its UV-scale to build a lattice where we're going to define our theory. This is one way to do it… another way is to use this realization of a UV-cutoff but rather than use it to define a latticized QFT, we can use it to define a Vertex Operator Algebra. The bottom line, in both cases, is that we're dealing with the problem of multiplying distributions (aka generalized functions) by defining some form of OPE: what lattices and VOAs do is to define the particular "point splitting" that your theory "likes" (i.e., that makes your theory "well behaved"). So, what you are effectively doing (pardon the pun) is defining your QFT via a particular choice of "point splitting" (OPE), be it with the help of a lattice, be it via VOAs. In the end of the day, however, what matters is that you, somehow, "discretized" your theory… and, as such, you can deal with it and circumvent Haag's theorem (which is only valid in the thermodynamic/continuum limit). This is what's behind the curtains.
  5. In some sense, this same discussion could be done regarding Statistical Mechanical models, e.g., the Potts Model, which is completely determined by its Transfer Matrix (analogous to the $S$ Matrix in QFT). However, when you try and take this continuum/thermodynamic limit… things get complicated really quickly. Of course this is a 'technical' point, a 'mathematical detail', and so on and so forth… but, I thought this was the whole point of this question… if I'm wrong, by all means, disregard these 'nitty picky'-points of mine. In any event, it is because of this limit to infinite degrees-of-freedom that QFT is more than just "S Matrix theory" or naïve extensions of Quantum Mechanics: as the saying goes, more is different. ;-)
Anyway, this is getting long and it's getting late (i.e., I'm getting hungry ;-)… and my point wasn't to give a scholastic answer, but to frame this discussion into its appropriate path. I hope this helps a bit.
Ruslan
  • 30,001
  • 70
  • 154
Daniel
  • 4,255
12
The original two questions deserve short clear answers. In reverse order:
2) "An example of a calculation which fails due to Haag's Theorem". Naive perturbation theory has to fail because of Haag's Theorem. And it does: when you compute the coefficients, they're mostly infinite.
1) "Why do QFT computations work, despite Haag's Theorem?" Because real QFT computations are not done in the interaction picture. Lattice QFT, as has been pointed out, doesn't use the interaction picture at all. Likewise, the LSZ formalism doesn't use the interaction picture. The only thing the interaction picture is used for is motivating an ansatz for the renormalized perturbation series. But when you switch to renormalized perturbation theory, you are actually abandoning the interaction picture, because you renormalize the field strengths.
user1504
  • 16,959
Lubosh wrote: "... perturbative QFT clearly works...". No, it miserably fails in the initial approximation ("bare" particles, no soft radiation predicted) and in course of search of the solutions by iterations (infinite corrections to the initial approximation). That is why there are so many questions to it!
What is comparable with experimental data is a renormalized and IR summed up result (a "repaired solution") which is quite different from the original solution. And even after that there are conceptual and mathematical difficulties in the theory. Besides, there are non-renormalizable theories where attempts to "repair solutions on go" fail hopelessly.
QFT, as a human invention, suffers from severe problems. It is very far from a desired state and needs repairing. Some times renormalizations "work" but not always, and we are far from the statement "QFT has no problem". We should try other constructions. I disagree with the Lubosh's statement "this is not possible", especially if with help of renormalizations and IR contribution summation we go away from initially wrong approximation and obtain reasonable results. I believe we may start from a better initial approximation, eliminate those problems, and arrive at the final results directly. Denying such opportunities is not wise, to say the least.
Haag's theorem and its present discussion touches the difference between mathematics and physics. While mathematics is based on axioms and consists of theorems physics is supposed to explain our experiences within a restricted set of mathematics. According to this separation Haag's theorem belongs to mathematics.
The reason is that the mathematics of physics is in principle discrete, finite. Have you ever measured something which is infinite? Have you met physical laws which apply at every scale to give a chance for infinities to appear? The naive quantum field theory formalism, cast in continuous space-time leads to infinities only if we extrapolate the observed physical laws to infinitely short distances. The remedy of this problem is well know: The physical laws are applied only within the range where they are observed. To be more elegant, they are used in a wider range and this widening is controlled by the short and the long distance cutoffs, the reflection of our ignorance.
The convergence and limit are concepts of mathematics and are used in physics in the procedure to keep the cutoffs out of the way and to hide the resulting distant scales in our equations. The convergence of removing the short distance cutoff, renormalizability is a convenience rather than necessity in physics, e.g. the non-asymptotically free sectors of the Standard Models are presumably trivial and non-renormalizable, the space-time is supposed to show granulated structure down to Planck's scale.
What is needed in physics is a regulated quantum field theory which provides a mathematically well defined, contradiction-free platform to study the observed phenomemons with flexible range of cutoffs. We have that, e.g. lattice field theory.
The axiomatic and constructive field theory and Haag's theorem in particular has a very important role to play in physics: They draw the attention to the precise limit of physical sciences within the vast set of beautiful mathematical concepts.
Janos
