Suppose you have a bosonic theory in a lattice
\begin{equation} H=\sum_{<i,j>}c_1a^+_ia^-_j+c_2(a^+_ia^+_j+a^-_ia^-_j\big) \end{equation}
Where $\{a^{\pm}_i\}$ are bosonic creation and anihilation operators, $c_1$ and $c_2$ are arbitrary constants and $<i,j>$ means sum over neighbouring sites in a lattice. This is just an example, it could have interaction terms too.
I was wondering if there was a way to take this Hamiltonian to the Path Integral Formalism. Something similar to the Hubbard-Stratonovich transformation for the Ising model, where one replaces the ising variables in the lattice $\sigma_i$ for a continuous field $\phi (\vec{r})$ and the partition function becomes a path integral for a $\lambda \phi^4$ theory.
Is there a way to take the continuum limit to a quantum field theory from a bosonic theory in a lattice?
To simplify the matters and reduce notational clutter, let's assume we have a 1d chain with nearest-neighbour hopping/interaction, described by the Hamiltonian, $$ H = t \sum_{\langle i,j \rangle} a_i^\dagger a_j + \Big( V \sum_{\langle i,j \rangle} a_i a_j + \text{c.c.} \Big) ~. $$
To systematically obtain the long-wavelength (low-energy) continuum limit of this Hamiltonian, we should first perform a Fourier transformation to momentum representation, using
$$ \begin{align*} a_k &= \frac{1}{\sqrt{N}} \sum_{l} e^{i k x_l} a_l \\ a_l &= \frac{1}{\sqrt{N}} \sum_{k} e^{i k x_l} a_k \\ \delta(k) &= \frac{1}{N} \sum_{l} e^{i k x_l} \\ \delta(x) &= \frac{1}{N} \sum_{k} e^{i k x} ~, \end{align*} $$
where $l$ is the lattice index, $k$ is the momentum, $N$ is the number of lattice sites, and we have used the ‘natural’ units where $ \hbar = 1 $.
The first term of the Hamiltonian can be rewritten as $$ \sum_{\langle i,j \rangle} a_i^\dagger a_j = \sum_{i, n = \pm 1} a_i^\dagger a_{i + n} ~, $$
because of our assumption of nearest-neighbour hopping on a 1d chain. This can be indeed generalized with little effort to any kind of lattice in any dimension ($n$ becomes a vector then). This paves the way for the Fourier transform:
$$ \begin{align*} \sum_{\langle i,j \rangle} a_i^\dagger a_j &= \sum_{i, n = \pm 1} a_i^\dagger a_{i + n} \\ &= \frac{1}{N} \sum_{i,n} \sum_{k, q} e^{i (q - k) x_i} e^{i q n a} \, a_k^\dagger a_q \\ &= \sum_{k, q, n = \pm 1} \delta(q - k) \, e^{i q n a} \, a_k^\dagger a_q \\ &= \sum_{k} ( e^{i k a} + e^{-i k a} ) \, a_k^\dagger a_k = \sum_{k} 2 \cos(k a)\, a_k^\dagger a_k ~, \end{align*} $$
where we have used the Fourier transform relations above, and $ x_{i + n} \equiv x_i + n a $ with $a$ denoting the lattice spacing.
Similarly, one can show that
$$ \sum_{\langle i,j \rangle} a_i a_j = \sum_{k} 2 \cos(k a)\, a_k a_{-k} ~. $$
Therefore, the Hamiltonian in momentum representation reads
$$ H = 2t \sum_{k} \cos(k a)\, a_k^\dagger a_k + \Big( 2V \sum_{k} \cos(k a)\, a_k a_{-k} + \text{c.c.} \Big) ~. $$
Now we can take the long-wavelength limit by assuming that the characteristic wavelength of the excitations, $\lambda$, is much larger than the lattice spacing, $a$; ie., $ \lambda \gg a $ or $ k a \ll 1 $ which allows an expansion of the dispersions in terms of $ k a $:
$$ \cos(ka) = 1 - \frac{1}{2} (k a)^2 + \mathcal{O}\left( (k a)^4 \right) ~. $$
Neglecting higher-order terms, we end up with an effective long-wavelength Hamiltonian,
$$ \begin{align*} H_{\lambda \gg a} &\approx 2t \sum_{k} a_k^\dagger a_k - t \sum_{k} (k a)^2 \, a_k^\dagger a_k \\ &+ \Big( 2V \sum_{k} a_k a_{-k} - V \sum_{k} (k a)^2 \, a_k a_{-k} + \text{c.c.} \Big) ~. \end{align*} $$
Such neglects of higher-orders can be substantiated via RG arguments; consult eg., Kopietz et al. “Introduction to the Functional Renormalization Group” (2013) [wcat].
It is straightforward to show, via a Fourier transform back to position representation, that
$$ \begin{align*} \sum_{k} a_k^\dagger a_k &= \sum_{l} a_l^\dagger a_l \\ \sum_{k} (k a)^2 a_k^\dagger a_k &= a^2 \sum_{l} \frac{\partial}{\partial x_l} a_l^\dagger \, \frac{\partial}{\partial x_l} a_l \\ \sum_{k} a_k a_{-k} &= \sum_{l} a_l a_l \\ \sum_{k} (k a)^2 a_k a_{-k} &= a^2 \sum_{l} \frac{\partial}{\partial x_l} a_l \, \frac{\partial}{\partial x_l} a_l ~. \end{align*} $$
Hence,
$$ H_{\lambda \gg a} \approx 2 t \sum_l a_l^\dagger a_l - t a^2 \sum_l \partial_{x_l} a_l^\dagger \partial_{x_l} a_l + \Big( 2 V \sum_l a_l a_l - V a^2 \sum_l \partial_{x_l} a_l \partial_{x_l} a_l + \text{c.c.} \Big) ~. $$
or better, using a suggestive notation,
$$ \begin{align*} H_{\lambda \gg a} &\approx 2 t \sum_l \frac{\Delta x}{a} \, \varphi^\dagger(x_l) \varphi(x_l) - t \sum_l \frac{\Delta x}{a} \, \partial_{x_l} \varphi^\dagger(x_l) \partial_{x_l} \varphi(x_l) \\ &+ \Big( 2 V \sum_l \frac{\Delta x}{a} \, \varphi(x_l) \varphi(x_l) - V \sum_l \frac{\Delta x}{a} \, \partial_{x_l} \varphi(x_l) \partial_{x_l} \varphi(x_l) + \text{c.c.} \Big) ~, \end{align*} $$
where $ \Delta x \equiv a $, $ \varphi(x_l) := a_l $ and we have introduced the dimensionless coordinates, $ x \mapsto \frac{x}{a} $. Now we can take the continuum limit ($ a \rightarrow 0 $), so that
\begin{align*} H_{\lambda \gg a} &\approx \int {\mathrm{d} x} \Big\{ 2 t \, \varphi^\dagger(x) \varphi(x) - t \, \partial_x \varphi^\dagger(x) \partial_x \varphi(x) + \Big( 2 V \, \varphi(x) \varphi(x) - V \, \partial_x \varphi(x) \partial_x \varphi(x) + \text{c.c.} \Big) \Big\} ~. \end{align*}
An analogous procedure can be performed in the functional-integral/action formalism, but the steps are the same.
This is essentially a “gradient expansion”. Notice that since the Hamiltonian is quadratic, there is no need for a Hubbard-Stratonovich transformation.
AlQuemist
  • 2,099
Yes there is a way. since you ask how to do it for a lattice I won't explain it indetail I only tell that part.
you have to use this following completeness relation;
$$\prod_{i}d\bar{\psi_i}d\psi_i/\pi\exp[-\sum_i\bar{\psi_i}\psi_i]|\psi\rangle\langle\psi|=1_{fock}$$ this is how to write a $1$ in fock space in terms of coherent states. $i$'s are the lattice sites, $|\psi\rangle$ is the coherent states and we also have , $a_i|\psi\rangle=\psi_i|\psi\rangle$. The rest is straight forward you just need to write your partition function and then you need to make a Suzuki-Trotter expansion using these $1$'s I provided, then you will have you partition function in path integral formalism in a lattice. The key point is to use bosonic coherent states, and using the completeness relation.
physshyp
  • 1,449
