Let $$L~=~-mc^2\sqrt{1- \frac{|\textbf{v}|^2}{c^2} },$$ where $\textbf{v}$ is the usual velocity of the particle in a fixed inertial frame. Then, this is the Lagrangian for a relativistic free particle. Now what does it mean by "the conserved quantity for a Lorentz boost"? Does it mean that the particle is boosted by some fixed velocity and there comes out a quantity that is preserved? I cannot get the exact meaning of the phrase. Could anyone please explain to me?
This is easiest to see from the Hamiltonian formulation, cf. this Phys.SE post. Below we will also give the non-relativistic expressions for comparison, because it is interesting and somewhat subtle, cf. this Phys.SE post, and because OP asked the analogous non-relativistic question earlier.
I) The Hamiltonian is the kinetic energy, i.e the energy minus the rest energy$^1$ $$\begin{align} H~=~&p^0c-mc^2~=~\sqrt{{\bf p}^2c^2+m^2c^4}-mc^2\cr \longrightarrow&\quad \frac{{\bf p}^2}{2m}\quad\text{for}\quad c\to \infty.\end{align} \tag{1} $$
The 3 boost generators $B^i$ are part of the 6 Lorentz generators $$\begin{align}B^i~=~&\frac{J^{0i}}{c} ~=~tp^i-x^i\frac{p^0}{c}\cr \longrightarrow &\quad tp^i-mx^i\quad\text{for}\quad c\to \infty,\cr & i~\in~\{1,2,3\}.\end{align}\tag{2}$$ The pertinent infinitesimal quasi-symmetry transformations are generated by the boosts $$\begin{align}\delta x^i ~=~&\{ x^i , {\bf B}\cdot \delta {\bf v} \} ~=~t~\delta v^i - \frac{p^i}{p^0c}{\bf x}\cdot \delta {\bf v}\cr \longrightarrow &\quad t~\delta v^i\quad\text{for}\quad c\to \infty, \tag{3}\cr \delta p^i ~=~&\{ x^i , {\bf B}\cdot \delta {\bf v} \} ~=~\frac{p^0}{c}\delta v^i\cr \longrightarrow &\quad 0\quad\text{for}\quad c\to \infty,\tag{4}\cr \delta t~=~&0.\tag{5}\end{align}$$ The Hamiltonian Lagrangian $$\begin{align} L_H ~=~&{\bf p}\cdot \dot{\bf x} - H \cr \longrightarrow &\quad {\bf p}\cdot \dot{\bf x} - \frac{{\bf p}^2}{2m} \quad\text{for}\quad c\to \infty \end{align}\tag{6}$$ has a quasi-symmetry $$\begin{align}\delta L_H~=~&\frac{d}{dt}\left( \frac{m^2c}{p^0} {\bf x}\cdot \delta {\bf v} \right)\cr \longrightarrow &\quad \frac{d}{dt}\left( m {\bf x}\cdot \delta {\bf v} \right) \quad\text{for}\quad c\to \infty. \end{align}\tag{7}$$ One may check that the corresponding Noether charges are precisely the boost generators (2).
II) The corresponding Lagrangian formulation$^1$ $$\begin{align}L~=~&mc^2\left(1-\sqrt{1-\frac{\dot{\bf x}^2}{c^2}}\right)\cr \longrightarrow &\quad \frac{1}{2}m\dot{\bf x}^2\quad\text{for}\quad c\to \infty,\end{align}\tag{8}$$ has infinitesimal boost quasi-symmetry $$\begin{align}\delta x^i ~=~&t~\delta v^i - \frac{\dot{x}^i}{c^2}{\bf x}\cdot \delta {\bf v}\cr \longrightarrow &\quad t~\delta v^i\quad\text{for}\quad c\to \infty, \tag{9}\cr \delta t~=~&0,\tag{10}\end{align}$$ and conserved boost charges $$\begin{align}B^i~=~&m\frac{t\dot{x}^i-x^i}{\sqrt{1-\frac{\dot{\bf x}^2}{c^2}}} \cr \longrightarrow &\quad m(t\dot{x}^i-x^i)\quad\text{for}\quad c\to \infty.\tag{11}\end{align}$$ This is left as an exercise to the reader. One way is to integrate out the 3-momentum ${\bf p}$ from the Hamiltonian formulation in section I. See also this related Phys.SE posts and links therein.
$^1$ We have removed the rest energy, which is a constant, i.e. a total time derivative, in order to be able to go to the non-relativistic limit.
- 220,844
