The reason I want to know is because many years ago in Sunday school I learned a story that in probably 600 AD some sinner was swallowed up by a hole, and that he's still falling as of today.
I can't use the formulas I know because they all assume g as constant, and I realized that I can't assume g=9.8 the entire fall because he's getting closer and closer to the center of the earth, so I tried to use my fairly bad calculus skills and failed miserably. Can anyone do this problem? Is it even possible?
It would help if you provide your calculations; probably I or someone else will see and correct your errors. However, a correct approach would recognize that at any distance $r$ from the center of the Earth, Earth's radius R, the gravity the falling man experiences is only $r^3 / R^3$ times the gravity experienced at the surface of the Earth. -- that is, assuming the density of the Earth is uniform. It comes to about 21 minutes, if there is no air resistance, to reach the center.
S. McGrew
  • 25,240
  • 32
  • 81
