13
There's a standard argument I've never understood. Consider the Standard Model in unitary gauge, where the $W$ and $Z$ bosons are just massive vector bosons. Then the propagator takes the form $$D_{\mu\nu}(k) = \frac{i}{k^2 - m^2} \left(\eta^{\mu\nu} - \frac{k^\mu k^\nu}{m^2} \right).$$ As the argument goes, a typical propagator falls off as $1/k^2$, but this propagator instead approaches a constant for large $k$. Therefore, loop integrals are more divergent than we would expect from naive power counting, and it is not apparent the theory is renormalizable.
But I don't understand this argument. It seems to apply to literally any theory with a massive vector particle, such as the Proca theory, $$\mathcal{L} = - \frac14 F_{\mu\nu} F^{\mu\nu} + m^2 A_\mu A^\mu$$ where there is no gauge symmetry, just a single massive vector. Why wouldn't this theory be renormalizable? There aren't any couplings with negative mass dimension. Does this argument not apply to the Proca theory, or does the standard effective field theory paradigm break down for massive vectors? If so, that's really disturbing to me, because I thought the effective field theory dimensional analysis worked on very general grounds; when else does it break down?
knzhou
  • 107,105
There are several steps involved in determining the renormalisability of a theory.
Typically, you want to first check by power counting if its divergences are likely to be manageable. This can be done by examining the superficial degree of divergence of loops of arbitrary order (see eg the book "Gauge theory...."by Cheng and Li).
If the theory seems to be renormalisable by power counting, then you are hopeful and, if you are so determined, might proceed to a rigorous proof which involves showing that all divergences to all orders can be absorbed by renormalising a finite number of parameters in the Lagrangian, while still maintaining all desired symmetries. Such full proofs are usually not discussed in detail in textbooks but you can find them in research articles or technical monographs.
Now, the Proca theory you mentioned does not look good from the power counting point of view because of the bad behaviour of its propagator. But it turns out that because there is still a conserved current, $k^\mu j_\mu =0$, the bad part of the propagator gets deleted in your loops (when vertices hit propagators). A full analysis confirms that the Proca theory (neutral massive vector boson) is renormalisable.
But that good fortune does not extend to non-abelian gauge theories where the vector bosons get a mass through an explicit symmetry breaking term. That was why there was a great deal of uncertainty in the early days on how to construct a sensible model for the weak interactions (which involved charged massive vector bosons).
The day was saved by the Higgs mechanism whereby the non-abelian vector bosons get a mass through "spontaneous symmetry breaking". The gauge symmetry ("gauge redundancy" more accurately) is still there but it is hidden, and you can choose your favourite gauge. The unitary gauge displays the physical content of the theory but it is not good for discussing renormalisability. But since you have the gauge symmetry, you are free to choose another gauge where the analysis of renormalisability is more transparent.
The rigorous proof of the renormalisability of spontaneously broken theories is non-trivial and was done by t'Hooft and Veltman, for which they were eventually awarded the Nobel prize.
Indeed before the proof that spontaneously broken gauge theories were renormalisable, most physicists did not take the Weinberg-Salam model seriously as the conventional wisdom then was that massive non-abelian vector bosons could not be part of renormalisable theories.
So in brief, the main points are: there are quick and dirty power counting rules which we use to gain some insight, but there can be "miracles" which save a seemingly lost day. A definite answer requires a careful detailed analysis.
BjornW
  • 7,217
rparwani
  • 964
