Discussions in the literature (e.g. https://arxiv.org/pdf/1412.2040.pdf) say in no uncertain terms that it is meaningless to consider time variations of fundamental dimensionful parameters such as c, G, ... If one must consider this type of thing, one must use dimensionless parameters. Fine, the arguments seem reasonable.
But what if one wishes to investigate a theory where a (nearly)classical theory morphs through time continuously into a fully relativistic theory. The naive way to approach it would be to make c vary with time, starting with some very large value and decreasing. But that is not permitted.
Is this because such a theory is physically unrealizable?
Similar question: is it meaningful to say that two universes in the multiverse differ in their value of a dimensionful parameter, say, hbar, and that this difference has anthropic consequences?
Last similar question: Can a theorist predict roughly the properties of a model of the universe where hbar is replaced by hbar/2? I assume the answer to this is YES.
I do not feel that this is a duplicate. The referenced discussion (which an excellent link) is relevant (and mentions the same paper that I identify) but my problem is really - how does one interpret the paper. Can I predict different physics for separate universes, for example? Can I have a weakly relativistic universe that morphs into a strongly relativistic one? Or a completely nonrelativistic that changes into relativistic?
