I am totally confused by the non-conservative forces.
I know that a non conservative force is either a force for which the work will be path independant (and only depends on the boundaries), or in an equivalent way, a force that depends on a potential.
But for me it is always possible to find such a potential.
I will take the typical example of the friction as the non conservative force.
I have $$\delta W = F dx = -k \frac{dx}{dt} dx$$
I will forget the $-k$ because it is not very important for what I want to say.
Let's consider I have a bijective motion, I can write $x=f(t)$ and $t=f^{-1}(x)$
Thus, $$\frac{dx}{dt}(t)=\frac{dx}{dt}(f^{-1}(x))=g(x)$$
And I always can find a primitive associated to $g(x)$ : $G'(x)=g(x)$.
Thus, I have $$\delta W=g(x)dx=dG$$
Thus the force is conservative. I don't understand.
Here I made two main assumptions :
- Bijective motion
- Existence of the primitive
I think the second assumption is not the problem (I only have to assume that $f$ is continuous).
Maybe the problem is linked to the first assumption, maybe for bijective motion between $x$ and $t$ the forces are always conservatives.
But I think my mistake is somewhere else, but as I really don't find it I am asking for help.
I would like to have an answer linked to the "little maths" I used here using derivatives and primitives.
