Ideally, I'd like to find some polar function for the orbit of a point particle that takes time as its argument, and for given boundary conditions (e.g.: initial radial velocity of particle) will give future radial displacement (etc.) in polar co-ordinates. Here's what I have for the equations of my two degrees of freedom ($r(t)$ and $\theta(t)$), using Lagrange's equation $\frac{d}{dt}\left[\frac{\partial L}{\partial\dot q_i}\right]=\frac{\partial L}{\partial q_i}$:
$$\ddot\theta r+2\dot\theta\dot r=0$$ $$\ddot r=r\dot\theta^2+\frac{GM}{r^2}$$
Does anyone know how I might go about solving these differential equations? Solutions would be helpful, especially those leaving boundary conditions as clearly expressed variables.
There is no closed form solution to these coupled differential equations.
The best you can do is combine them to get an analytical expression for $r$ in terms of $\theta$, producing the familiar equations for parabolae, ellipses, or hyperbolae, defining the orbit's shape. The remainder is found using some form of numerical integration on one of the differential equations for $r(t)$ or $\theta(t)$, with the constraint from the orbit's shape.
Sean E. Lake
  • 22,927
