-1
A simple maybe 8th or 7th grader question, but I can't really get over it. Elastic collision: momentum is conseved and so is the kinetic energy whereas in an inelastic collision, momentum is conserved but not the energy. Although I don't get it why is momentum of a closed and isolated system is supposed to be constant/conserved just accounting to the fact that system is closed (no mass enters or leave it) and isolated (no net external force) but, ok, let me accept this for a minute and think about how is it possible that momentum is conserved but the kinetic energy of system changes as happening in an inelastic collision.
I mean since both quanties depend on velocities of object initially and finally, both of them should act alike. If one changes, other does too. If one doesn't, other doesn't as well.
There is general conservation law - conservation of total energy and momentum. Imagine that two balls of the same mass move towards each other with the same velocity (in opposite directions) and then collide absolutely inelastic so at the end we have one entire body at rest. So momentum is conserved (and equal to zero). It is not in a contradiction with the fact that kinetic energy is not conserved because there are other forms of energy here.
LRDPRDX
  • 809
This is not a complete answer to your question, but it may give you some insight… Consider a head-on collision, observed in the laboratory frame of reference, between two spheres of equal mass. There will be another frame, known as the centre of mass (CM) frame, in which the same collision is seen as the spheres approaching each other with equal and opposite velocities.
For example suppose the spheres have lab-frame initial velocities in the x-direction of $u_1$ and $u_2$. The CM frame is the frame moving in the x-direction with velocity $\frac{u_{1}+u_{2}}{2}$. In this frame the spheres will have initial velocities $\frac{(u_{1}-u_{2})}{2}$ and $\frac{(u_{2}-u_{1})}{2}$ [Galilean transform].
Now, whether the collision is elastic or inelastic, it is a matter of symmetry that in the CM frame the spheres' velocities after the collision will be equal and opposite. Call them $v_{CM}$ and $-v_{CM}$. If the collision is inelastic these velocities will be of smaller magnitude than the initial velocities in the CM frame. In the laboratory frame these velocities will be $v_{CM} +\frac{u_{1}+u_{2}}{2}$ and $-v_{CM} +\frac{u_{1}+u_{2}}{2}$. So the vector sum of 'final' velocities in the lab frame is $u_{1}+u_{2}$, that is momentum is conserved!
Note that we've achieved this result by using little more than symmetry and the Galilean velocity transform between reference frames. Clearly things aren't quite as simple for bodies of different mass, but the message is the same: conservation of momentum can be regarded as a consequence of a spatial symmetry.
We note that the argument depended on the vector nature of momentum (or of velocity). The same argument could not be used for the scalar, kinetic energy.
Philip Wood
  • 37,325
Since both quanties depend on velocities of object initially and finally, both of them should act alike
Kinetic Energy has a v squared term in it so you simply consider the magnitude.
Momentum has only a v term in it so you consider both the direction and magnitude.
SmarthBansal
  • 1,035
