Possible Duplicate:
What does it mean to say “Gravity is the weakest of the forces”?
Strongest force in nature
It is usually taught that the gravitational force is the weakest but I wanted to know if it will be always so. For example, On earth gravity is weaker than electromagnetic force or weak nuclear force, so is it that on black hole also if gravity is strongest than other forces shall be more stronger than it or it's that gravity becomes most strong suppressing others.
Because if other forces increase in same proportion than it will have serious implications.
Your question isn't as straightforward as you might think, because if you drop an atom into a black hole it will fall freely and will not feel any force attracting it to the black hole. This sounds odd, but it's the same reason that astronauts in the International Space Station feel weightless even though they're being attracted by the Earth's gravity. A freely falling object doesn't feel any gravitational force.
However, an object falling into a black hole will feel tidal forces. This happens because one side of the atom is slightly nearer the black hole than the other side, so it's attracted more strongly. The end result is that the atom is stretched in the direction toward the black hole and squeezed in the direction at right angles to its motion. This is known somewhat colourfully as spaghettification.
So the question really is whether at some point the tidal forces get so strong that they tear the atom apart. Presumably, first, the electrons would be torn off then the nucleus would be torn apart.
Well, the key feature of a black hole is that classically (i.e. ignoring quantum theory) the singularity at the centre of the black hole has zero size and the tidal forces at the singularity are infinite. This means that yes, at some point the tidal forces will get stronger than even the strong force and the atom will be completely torn apart. Presumably, even the protons and neutrons would be torn into separate quarks.
But, and it's a big but, we almost certainly can't treat this classically because we expect quantum effects to become important that close to the singularity. Exactly what will happen no-one knows because we don't have a theory of quantum gravity that can describe this situation. If String Theory is the correct description at such small distances then presumably at around the string scale from the centre the atom would start behaving as a collection of separate strings rather than the particles we are familiar with.
Response to comment:
Suppose you're hovering above a black hole and you let down a rope until it touches the event horizon. The rope will always be torn apart. This happens because all forces, electrostatic, strong and weak, propagate at the speed of light, and at the event horizon even the speed of light is not high enough to escape.
So if this is the experiment you're thinking off, then once your charged particle has got sufficiently close to the event horizon you would not be able to pull it back out with a particle of the opposite charge.
However, this isn't to do with the fundamental strength of the gravitational force. It's because one electron has a hard time resisting the gravitational force of an entire black hole.
Response to response to comment:
If you're asking "Is gravity stronger than the electromagnetic force" then you need to define what you mean. You are quite correct that at a black hole event horizon, the electromagnetic force would not be enough to hold together an object that partially crossed the event horizon. In that sense gravity at the event horizon is stronger than the electromagnetic force, and indeed it's stronger than any force.
But a physicist would not conclude gravity was stronger because you're not comparing like with like. To do a fair comparison you need to take two test particles with both charge and mass, put them some set distance apart and measure first the electrostatic force between them, then the gravitational force between them. Whether you're near a black hole or not, this experiment will conclude that the gravitational force is much much weaker than the electrical force.
If you conclude that gravity is stronger than electromagnetism at an event horizon all you're really saying is that the gravitational force due to the (at least) $10^{31}$ kilograms of a black hole is stronger than the electrostatic force from the $10^{-19}$ coulombs of charge on an electron. Well, yes, that's not terribly surprising!
John Rennie
  • 367,598
