Can somebody explain what does it mean when a solution is "asymptotically flat"? like the schwarzschild metric which is asymptotically flat solution to vacuum Einstein equations.
The definition of asymptotic flatness varies from text to text, but there are in general, 3 conditions for a solution of Einstein's field equations to be considered asymptotically flat. Consider a spacetime $(\hat{M}, \hat{g}_{ab})$, with the following 3 properties:
  1. There exists a function $\omega \geq 0$, such that $g_{ab} = \omega^2 \hat{g}_{ab}$,
  2. On the boundary, one has $\omega = 0$, and $\omega_{,a} \neq 0$,
  3. Every null geodesic intersects the boundary at two points.
Such spacetimes are called asymptotically simple. But, now if the metric tensor $g_{ab}$ is indeed a solution of the Einstein field equations, the spacetime then is considered asymptotically flat.
For the Schwarzschild solution, it is easiest to see this using null coordinates, $u,v$, which the metric then takes the form:
$ds^2 = -dudv \left(1 - \frac{2M}{r}\right) + r^2 \left(d\theta^2 + \sin^2 \theta d\phi^2\right)$, where $r = r(u,v)$. So, make the further coordinate transformation:
$\tan U = u, \tan V= v$,
then one can show that the conformal metric takes the form:
$ds^2 = \cos^{-2}U \cos^{-2}V \left(1- \frac{2M}{r}\right) dU dV + r^2 \left[d\theta^2 + \sin^2 \theta d\phi^2\right]$.
Now, if you let $\omega = \cos U \cos V$, this can be written as:
$ds^2 = \omega^{-2}\left[ \left(1- \frac{2M}{r}\right) dU dV + r^2 \omega^2 \left(d \theta^2 + \sin^2 \theta d\phi^2\right)\right]$
Now, at the boundary where $\omega = 0$, we have clearly that $U = \pm \pi/2$ or that $V = \pm \pi/2$, i.e., we have "mapped the infinities $u,v = \pm \infty$ to finite values. Since clearly $r \omega \neq 0$ when $\omega = 0$ then, the boundary consists of two points being intersected.
This is an idea of how one shows that the Schwarzschild metric is asymptotically flat.
If you want more details on this, I suggest you look at Wald's classic text.
