This question, and ones like it, seem to defy satisfactory explanation for non-physicists. PEP is referred to as Pauli "repulsion", or Pauli "pressure", while it is simultaneously denied to be a force, or result in a force. Comparisons are made to ideal gases. Apologies have been offered for technical jargon being mistaken for the lay person's notion of "force". Copious math Is done to describe acceptable and forbidden behavior of particles. Yet none of the four fundamental interactions, nor indeed a fifth force, is said to be responsible for keeping electron clouds from overlapping too much (solidity of matter questions), or neutrons from collapsing further in a neutron star.
Ideal gas behavior is straightforward and intuitive enough. It's easy to see that many small fast moving particles exert an average force on their container and vice versa. But at the particle level (can we assume hydrogen gas in a balloon?), the same question arises: what force, during the impulse time of an H atom collision with the container wall, changes the particle's momentum? Again, PEP would appear to be the cause, because this is really no different than the solid object question. But, PEP is not a force, so how does a particle undergo a change in momentum without a force?
Tom B.
  • 867
Here's a slightly different approach that might help.
Consider two isolated particles interacting by an arbitrary central force, with angular momentum $L \neq 0$ with respect to each other. As long as the force remains finite, it's impossible for the particles to ever hit each other: whenever they get closer, they will necessarily speed up by conservation of angular momentum, creating a 'centrifugal potential barrier' $$V(r) = \frac{L^2}{2mr^2}.$$ In a reference frame that rotates with the particles, it looks like a new force has appeared, which gets stronger the closer the particles get, preventing them from occupying the same position.
This apparent force has nothing to do with any of the four fundamental forces and doesn't depend at all on what the force between the particles is -- it could be strong, electromagnetic, gravitational, or something else entirely. But the centrifugal force is not a new force; it just follows from the kinematics of the situation and the conservation laws.
Abstractly, you can think of the possible configuration space of the particles as being restricted to states with angular momentum $L$, and this restricted space contains no states with the particles on top of each other. Similarly, in the Pauli exclusion principle the state space is restricted to antisymmetric wavefunctions, which contain no configurations with the particles in the same state.
knzhou
  • 107,105
All the Pauli exclusion principle does is ensure that two fermions cannot occupy the same quantum state. This means that ideal fermions at high density have large momenta, on average, whatever their temperature.
The implied pressure is calculated in exactly the same way, using exactly the same kinetic theory, as for a classical ideal gas - assuming point-like particles undergoing elastic collisions. What is responsible for those elastic collisions is swept under the carpet when you make the ideal gas (NB degenerate gases can be ideal too) approximation. If you relax the ideal assumption, then the details matter - e.g. coulomb interactions, Thomas-Fermi corrections, exchange interactions, inverse beta decay etc.
A good example is that ideal neutron degeneracy pressure does not support (all observed) neutron stars; it is the residual strong force between closely packed neutrons that is mostly responsible and the details do matter.
ProfRob
  • 141,325
