-1
A thin uniform rod AB of mass $M$ and length $L$ is free to rotate in a vertical plane about a horizontal axle at end A. A piece of putty, also of mass $M$, is thrown with velocity $V$ horizontally at the lower end B while the bar is at rest. The putty sticks to the bar. What is the minimum velocity of the putty before impact that will make the bar rotate all the way around A?
(Gravity acts on the rod)
My strategy in solving this problem consisted of trying to find the kinetic energy of the system immediately after collision and then using the work done by gravity to find the minimum velocity.
$$L = m v l$$
The centre of mass of the system must then be $3L\over{4}$ the way down from the pivot A. Hence, the moment of inertia of the centre of mass about the pivot can be derived as:
$$I_{cm} = 2m ({3l\over{4}})^2$$
From which the angular velocity may be determined by the conservation of angular momentum:
$$w = {L \over{ I_{cm} }} = {m v l \over{2m({3l\over{4}})^2}} = {8v \over{9l}}$$
Hence, the final kinetic energy $$KE = 0.5 * 2m ({v\over{2}})^2 + 0.5 (2m({3l\over{4}})^2) * ({8v\over{9l}})^2$$
However, this is incorrect since the final kinetic energy is greater than the initial kinetic energy. The final answer should be $v = \sqrt{8gL}$, according to the book, however my attempts have been in vain. How should I go about this problem?
Chris
  • 17,377
Suppose putty is thrown with velocity v . Then use AMC abouthinge to find angular velocity of rod just after impact . Now do the side calculation of finding the minimum velocity to be given to lowermost part of rod to complete full circle by using work energy theorem .find velocity of bottommost point with help of angular velocity found earlier and equate.
