And what property is needed to own for this?
I can`t find this information
When a light wave strikes the surface of an object, a variety of things can happen. One of these things is called resonance. When resonance occurs between a light wave and an object, the object absorbs the energy of that light wave. The light energy stays inside the object when resonance occurs, and this is the reason for absorption of light.
An object is said to be transparent when light passes through it without being dispersed, or scattered. Clear glass is transparent, and clean water is transparent. Although light travels through these materials, we know that they also block things like wind, sound waves and the movements of people and animals. For example, you can't walk through glass. So, how can a light wave pass through the glass without being changed at all?
Light waves are absorbed by an object when the frequency of the light wave matches the resonant frequency of the object. Absorption occurs when none of the light waves are transmitted through the object. Transmission, if you weren't sure, just means the passing of electromagnetic waves through a material. In the case of objects that are transparent, all of the light waves pass through. Transparent objects exhibit complete transmission of the light waves through the object.
An object looks transparent because light waves pass through unchanged.
What really happens inside glass materials when a light wave passes through? We know that there aren't any tunnels connecting one side to the other. So, what's going on? When a light wave strikes the surface of the glass, it sets the electrons vibrating at a certain frequency. This frequency is not the resonant frequency of the glass. The vibrations pass from the surface atoms to the neighboring atoms and then on to more atoms through the bulk of the glass. The frequency doesn't change when the vibrations pass from one atom to another. Once this energy gets to the other side of the glass, it is re-emitted from the opposite surface. The light wave effectively passes through the glass unchanged. As a result, we can see straight through the glass, almost as though it isn't even there. So, now you know: transparency occurs because of the transmission of light waves through the bulk of an object.
When a light wave is neither absorbed nor transmitted by an object, then it is reflected.
Reflection is a change in the direction of a wave when it strikes a surface. Reflection can be specular (as in glossy or smooth-surfaced objects) or it can be diffuse (as in objects with rough surfaces). In either case, reflection occurs because the vibrations of the surface electrons do not pass their energy down through the material. Instead, they vibrate a little bit and then re-emit the energy back, away from the material. When this happens, the object appears to us as opaque. Opaque materials do not allow transmission of light waves. In other words, we can't see through an opaque object. We can only see the surface because the light waves are re-emitted from the surface back to our eyes. Opacity occurs because of the reflection of light waves off the surface of an object.
When light waves are reflected, an object appears opaque.
So, now you know that opacity occurs because of:
