The Hartree-Fock equations include a term for the exchange interaction, which is usually explained as a repulsive force due to the Pauli exclusion principle. (It says so right in the description for the "exchange-interaction" tag.)
I expect that, in a system of repulsive particles, increasing the particle density would increase the energy of the system. (E.g. if you have a bunch of particles connected by springs, you would have to work to compress the system, so the energy of the system increases when compressed.)
However, for a free electron gas (and for the local density approximation), the exchange energy becomes more negative as the density is increased [Ashcroft and Mermin eq. (17.26)]:
$$U_{ex} \propto -\left(n\left(\vec{r}\right)\right)^{1/3},$$
where $n\left(\vec{r}\right)$ is the electron density. [See also Ashcroft and Mermin eq. (17.24) and the two sections on Hartree-Fock.] I interpret this to mean that increasing the electron density results in lower energies due to the exchange interaction.
Why does the exchange interaction -- a repulsive force -- lead to lower energy as the particle density is increased?
lnmaurer
  • 4,375
The exchange interaction includes not only a term reflecting the repulsive Pauli interaction, but also a correction for the electron self-energy of the Hartree equations. That is because the electron density that is used to calculate the Hartree potential includes the density of the orbital of the electron under consideration as well as all the other electron orbitals. The Fock exchange term thereby includes a term that removes this self-energy. The self-energy is a repulsion, so the terms that corrects for it is an attractive interaction. If this dominates, then the overal Fock term will be attractive and will increase as the electron density increases.
Lewis Miller
  • 6,162
  • 19
  • 27
