Why doesn't the velocity of a photon change when it is emitted from a source moving with certain velocity? If a photon is a particle then it should have a lower velocity than one which is emitted from stationary source. But it is not true. How does a photon always gain constant velocity in spite of the source's motion? Is it accelerated according to the source's velocity inside an atom before being emitted? Or are there any other reasons behind this?
Ben51
  • 10,037
Light sometimes behaves like a wave, sometimes like a particle, but for most people the idea of a photon being a particle is misleading because we tend to think of a particle as having mass and taking up space. Because a photon has no mass it is required to travel at light-speed (which is actually the speed of causality). It does not gain velocity - from the very instant it is emitted it is going at the fastest possible speed.
Grrash
  • 1,016
Your question and objections make complete sense in a Galilean world, a world of 3 orthonormal space dimensions where time is independent and universal: that is, all observers agree on the same clock (and ruler). In such a place, all velocities are additive. (Note: our slow moving daily lives are approximately Galilean--and Galilean transformations can be used to transform reference frames).
In reality, we live (locally) in Minkowski space, where the space dimensions mix with the time dimension, and different moving observers have different clocks and rulers. One needs Lorentz transformations to connect reference frames.
If find the number one stumbling block to understanding the latter is the lack of simultaneity. Moving observers cannot always agree on time ordering, and forgetting this leads to many paradoxes (apparent, of course).
JEB
  • 42,131
For some object to change speed,- it needs to be accelerated/decelerated. This must happen in a time-window, $$ t= \frac{m \Delta v}{F} ,\tag 1$$ Since photon doesn't have a rest mass as per (1), you don't have any chance to speed-up or slow-down photon in a vacuum, because such process time window is zero. I.e. in other words photon isn't affected by inertia.
However, as every other thing in the universe,- it can loose or acquire a kinetic energy, $$ E_\gamma = h\nu \pm K = h(\nu \pm \Delta \nu) \tag 2$$
only for a photon this reflects as frequency increase or decrease. Also known as a Doppler shift if it happens due to light source or receiver movement.
BTW, photon can gain/loose energy not only due to a Doppler effect, but also due to other reasons such as universe expansion, direct and inverse Compton scattering and other mechanisms.
-1
In particle physics, photon is one of the fundamental ingredients of the Standard Model (SM) which explains all the particles/fields and their interactions. A symmetry group particularly $SU(3)_C\times SU(2)_L\times U(1)_Y$ governs all the properties and interactions of those particles. In very small distances ($\lt 10^{-18}$m) or at very high energies those particles are all required to be massless by the theory, at low energies however some of those particles acquire masses by a mechanism called symmetry breaking and photon associated with electromagnetic interactions stays massless. In Relativity, massless particles are destined to travel at the speed of light which is the ultimate limit for matter particles. That's why, for example, the range of the electromagnetic interactions is infinite. The answer of your question thus lies in 4-dimensional relativistic structure. As JEB already mentioned above that Lorentz transformations of 4D spacetime is quite different than Galilean transformations of 3D space.
