In most presentations of general-relativity I see the following statement,
We can change from a covariant vector to a contravariant vector by using the metric as follows, ${ A }^{ \mu }={ g }^{ \mu \nu }{ A }_{ \nu }$
My questions are,
  1. What is the need to do this particular change in relativity?
  2. The covariant components represent the components of a vector the contravariant components represent the components of a dual-vector, for finite dimensional vector spaces the two spaces are isomorphic. What is the significance of representing a quantity in contravariant or convariant forms? Is the need purely mathematical?
physicscircus
  • 598
  • 13
It matters of two different concepts. Given a manifold, a vector is a geometric object associated to each point in the manifold. It can be decomposed into components with respect to a set of basis vectors.
$A = A^\mu \hat e_{(\mu)}$
where:
$\mu = 0, 1, 2, 3$
$A$ vector
$A^\mu$ contravariant components
$\hat e_{(\mu)}$ basis vectors
The geometric object is a reality independently of the coordinate system. A characterization is given by its square.
$A^2 = A \cdot A = A^\mu \hat e_{(\mu)} \cdot A^\nu \hat e_{(\nu)} = \hat e_{(\mu)} \cdot \hat e_{(\nu)} A^\mu A^\nu = g_{\mu\nu} A^\mu A^\nu$
where:
$\cdot$ scalar (dot) product
$g_{\mu\nu} = \hat e_{(\mu)} \cdot \hat e_{(\nu)}$ metric tensor
The square can also be written as
$A^2 = A_\mu A^\mu$
where:
$A_\mu = g_{\mu\nu} A^\nu$
As per above, we can define the dual vector.
$\tilde A = A_\mu \hat \theta^{(\mu)}$
where:
$\tilde A$ dual vector
$A_\mu$ covariant components
$\hat \theta^{(\mu)}$ basis dual vectors
By demanding
$\hat \theta^{(\mu)} (\hat e_{(\nu)}) = \delta^\mu_\nu$
where:
$\delta^\mu_\nu$ Kronecker delta
we can write the action of the dual vector on the vector as
$\tilde A (A) = A_\mu \hat \theta^{(\mu)} (A^\nu \hat e_{(\nu)}) = A_\mu A^\nu \hat \theta^{(\mu)} (\hat e_{(\nu)}) = A_\mu A^\nu \delta^\mu_\nu = A_\mu A^\mu$
Hence, a dual vector is a linear map from the vector space to the real numbers.
By defining the inverse metric tensor as
$g^{\mu\lambda} g_{\lambda\nu} = \delta^\mu_\nu$
where:
$g^{\mu\nu}$ inverse metric tensor
we have also
$A^\mu = g^{\mu\nu} A_\nu$
  1. Because you need to identify vectors with covectors and that is possible only through the metric. If you think about components: you have upper and lower indices which reflect the way in which a tensor transforms under a change of coordinates. The position of indices reflects only that, thus I want something which allows me to indentify tensor with different disposition of indices.
  2. The difference is that if you lower an upper index you change the quantities it contains by the metric. If you have the momentum four-vector $P^\mu=(E, \textbf{p})$ and you lower the index, in particular, $P_o$ is not the energy anymore, since you get $P_o=g_{o\mu}P^\mu$.
This is just a rough treating though, cheers!
Bellem
  • 268
