The Proper Lorentz transformations are all matrix $\Lambda$ such that $\eta=\Lambda^T\eta\Lambda$ and $\det\Lambda=1$ with $\eta=\text{diag}(-1,1,1,1)$ the Minkowskian metric. $\textit{i,e}$, $\Lambda$ are the group $SO(3,1)$. This is a continuous group with six parameters and hence six generators. Three for the Lorentz boosts and three for spacial-rotations. Let $\vec B$ the generators for the boosts and $\vec R$ the generators for rotations.
A generic rotation in an axis $\hat n$ and an angle $\alpha$ is given by $$\Lambda(0,\vec\alpha)=\exp(\alpha\hat n\cdot \vec R)=\pmb I+\sin\alpha(\hat n\cdot \vec R)+(1-\cos\alpha)(\hat n\cdot \vec R)^2.$$
For a generic boost to a inertial frame with velocity $\vec v$ is given by $$ \Lambda (\vec\beta,0)=\exp(-\tanh^{-1}(\beta)\;\;\hat\beta\cdot \vec B)=\pmb I-\beta\gamma (\hat\beta\cdot \vec B)+(\gamma-1) (\hat\beta\cdot \vec B)^2 $$ with $\vec\beta=\beta\hat\beta=\vec v/c$.
My question is what the generic matrix for both, rotations and boost, is ? $$ \Lambda(\vec\beta,\vec \alpha)=\exp(-\tanh^{-1}(\beta)\hat\beta\cdot\vec B+\alpha\hat n\cdot \vec R)=? $$
The first and second expressions are proved showing that $(\hat n\cdot \vec R)=-(\hat n\cdot \vec R)^3$ and $(\hat\beta\cdot \vec B)=(\hat \beta\cdot B)^3$ respectively.
The main problem is that $$ e^{\pmb A+\pmb B}\not =e^{\pmb A}e^{\pmb B}, $$ when $[\pmb A,\pmb B]\not =0$. And $[R_i,B_j]=-\epsilon_{ij}^{\;\; k}B_k\not=0$, can you help me?
