Why the central concepts of classical mechanics, viz. Lagrangian and Hamiltonian formalisms cannot address constraint forces like friction and others in dissipative systems?
Asked
Active
Viewed 2,047 times
All the kinds of constraints you can have in your, say, lagrangian system must satisfy a relation called ideality of the constraint, which takes into account the so called virtual displacements, indeed it states: $$\sum_i\bar{N}_i\cdot\delta \bar{r}_i=0.$$ This is a statement you use for building your configuration space.
You see that this is a requirement which excludes dynamical frictions as constraints. Nontheless, you can use pure rolling as a constraint since in that case you demonstrate it is ideal.
Bellem
- 268
