In Bell's spaceship paradox a thread between equally accelerating spaceships breaks, because length contraction shortens the spaceships and the thread but not the distance between them. Wikipedia does not explain what happens when the observer accelerates instead of the spaceships, but I assume the thread does not break then.
Compare this with Purcell's description of electromagnetism replicated here and linked from here. The magnetic force on a (positive) test charge moving along a live wire is nothing but relativistic electrostatic force — the latter created due to a relativistically reduced distance between (negative) charges.
Moving the test charge past the wire is similar to the spaceship situation except the observer accelerates not the spaceships and the thread does not break. But why then should the distance between the negative charges in the wire shrink, but not the distances between the positive ones? Relativistically, the whole wire gets shorter in the frame of the moving test charge, but this would then decrease the average distance between all charges, not only the (in this case) negative charges.
Puzzled! Can someone explain this?
Similar, but I don't understand neither answer :-(
Harald
  • 771
Let's say observer observes initially positive charges not moving and negative charges moving. The observer is standing next to a electric wire where current is flowing. And then the observer starts to accelerate.
The accelerating observer observes the positive charges gaining more speed, and from that it follows that said observer observes distances between positive charges decreasing.
The same accelerating observer may observe the negative charges gaining speed or losing speed, depending on the direction of the acceleration. Therefore said observer may observe distances between negative charges decreasing or increasing.
Oh yes, speed of electrons relative to protons inside an electric wire is very small. So you are right, distances between both protons and electrons shrink, according to almost any accelerating observer.
But not exactly the same amount of shrinking occurs, as the speeds of protons and electrons are not exactly the same.
stuffu
  • 2,374
Your first example involves acceleration, and your second one doesn't. Special relativity distinguishes between inertial and noninertial frames of reference.
The observer in the magnetic example has a velocity, not necessarily an acceleration.
