If the gravity well of a non-rotating heavy object is in roughly the same inertial frame as an observer, its spacetime geometry (as measured e.g. by photon lensing) will present as spherically symmetric.
If the same object is passes near the observer at a linear velocity close to c, special relativity would seem to require that its gravity well present itself (e.g. through photon lensing) as both deeper and asymmetrically compressed in the direction of motion.
Is that correct? Does SR transform the shape of spacetime around fast-moving heavy objects, and does it do so in a fashion that is experimentally measurable using photons and other particles as probes?
[Note to readers: I stupidly used the phrase "rubber sheet model" in my first try at this question, so the first comments you will see below are referring to that version.]
Terry Bollinger
  • 22,299
  • 87
  • 136
