This answer and comments state that you can perform Young's two-slit interference experiment with white light and get a pattern of colored interference fringes. I've got some white LEDs lying around that I could use as a point source of light. Would one of these work as a light source for the experiment, or would the decidedly non-blackbody spectrum mess things up?
Asked
Active
Viewed 1,166 times
The point of the white light interference experiment is that all the light is interfering whatever the wavelength. The spectrum doesn't matter.
ps. Getting a white light pattern can be tricky, you could try with a single color LED first, or better still a laser pointer.
pps. A bare LED probably isn't enough of a point source for white light fringes - you might need a lens and a pinhole
Martin Beckett
- 31,032
