11
The Berry connection, following the derivation of the Berry phase for a non degenerate system, is
$\mathcal{A}_{k}(\lambda) = i \langle n|\frac{\partial}{\partial \lambda^{k}}|n\rangle$
This result is gauge-dependent, as seen making an analogy with the Aharonov-Bohm effect.
What I don't see is why this is a connection, and how it's related with the parallel transport of eigenstates along the parameter space. Also I haven't found literature that explained this didactically. Why is the Berry connection a connection?
vbarcelo
  • 373
The following figure depicts a closed path in the parameter space and shows the variation of the state's normalized eigenvectors in $n$ discrete point along the path. The last point of the path $n$ coincides with the first point $0$.
enter image description here The Berry phase is the total of the accumulated phases along the path: $$ \phi = \lim_{n \to \infty}\arg(\langle 0|1 \rangle\langle 1 |2 \rangle .,.,.,\langle n-1 | n\rangle\langle n | 0\rangle)$$ This definition makes sense, since it is gauge invariant and a local phase transformation on every point of the path $$|k' \rangle = e^{i \alpha_k}|k \rangle$$ does not change its value because: $$\langle l' |k' \rangle = e^{i \alpha_k - i\alpha_l}\langle l' |k' \rangle$$ We can choose a gauge transformations such that: $$|0' \rangle = |0 \rangle$$ (Initial condition), and $$\arg(\langle k' |k' +1\rangle) = 0 $$ The second condition makes the direction of the eigenvector at the $k+1$ -th point parallel to that of the $k$ -th point. Thus in the basis $|k' \rangle$, the vectors are parallel transformed.
Please notice that the last term in the Berry phase $\langle n | 0\rangle$ cannot be rotated to zero, because the phase of $|0'\rangle$ is fixed by the initial condition and the phase of $|n'\rangle$ is fixed by the condition $\arg(\langle n'-1 |n' \rangle)=0 $. Thus we are left with only one term in the Berry phase : $$ \phi = \arg(\langle n' | 0'\rangle)$$ It must be emphasized that the above expression is valid only in the parallel transport gauge system $\{|k' \rangle\}_{k=0, ., ., ., n}$. The value of this phase is equal to the original value due to gauge invariance.
Going to the continuum, we have: $$\arg(\langle k |k+1\rangle) \rightarrow \arg(\langle n(t) |n(t+\Delta t)\rangle) $$ Where in the continuum, we use the points $n$ in the parameter space to parametrize the eigenvectors; We have: $$|n(t+\Delta t)\rangle = |n(t)+\frac{d n}{d t} \Delta t \rangle = |n(t)\rangle + \frac{\partial |n(t)\rangle}{\partial n^i}\frac{dR^i}{dt}\Delta t$$ Thus: $$\arg(\langle n(t) |n(t+\Delta t)\rangle) =\mathrm{ Im}(\langle n(t) | \frac{\partial |n(t)\rangle}{\partial n^i})\frac{dn^i}{dt}\Delta t$$
(because the vector is normalized, we have $\arg(1+x) = \mathrm{Im}(x)$). The inner product $\langle n(t) | \frac{\partial |n(t)\rangle}{\partial n^i})$
is pure imaginary because:
$$\mathrm{ Re}(\langle n(t) | \frac{\partial |n(t)\rangle}{\partial n^i}) \rangle= \frac{1}{2} (\langle n(t) | \frac{\partial |n(t)\rangle}{\partial n^i}\rangle + \langle \frac{\partial |n(t)\rangle}{\partial n^i} | n(t)\rangle) = \frac{\partial }{2\partial n^i} \langle n(t)| n(t) \rangle = 0$$ (since $\langle n(t)| n(t) \rangle =1$).
Thus we may write the Berry phase as: $$ \phi = \oint \langle n(t) | \frac{\partial |n(t)\rangle}{\partial n^i})\frac{dn^i}{dt}d t$$
The integrand in the last expression is the Berry connection.
