Is the first time that I am asking something here, so I apologize if it is not the place, or I am not clear enough.
I am working on this problem where I have a protein place between 2 surfaces (top and bottom). The protein is bound originally to the surface in the top (a membrane) and can diffuse in this surface with a diffusion coefficient Dt. However, when the protein gets in contact with the second surface in the bottom, the protein can bind to this surface and diffuses with a diffusion coefficient Db. Do you think that it is possible to estimate an effective diffusion coefficient for the protein? Or the lower motility will be the limiting factor? Db
If the protein attaches to the bottom surface at a rate $k$ and detaches at a rate $\nu$ then the probability of finding the protein attached to the bottom surface at any given moment is:
$$ P = \frac{\nu^{-1}}{k^{-1}+\nu^{-1}} $$
The mean diffusion coefficient is then just a weighted average:
$$ \langle D\rangle = PD_b + (1-P)D_t $$
You can see this to be true by computing the mean-square displacement over a time interval $k^{-1}+\nu^{-1}$, which I'll leave as an easy exercise.
lemon
  • 13,320
