Operational definitions are constructed from the observations we make in nature. Experiments show us that two objects $m_1$ and $m_2$ in a local inertial frame, isolated from the rest of the universe, interact in a way such that the ratio of their accelerations $a_1$ and $a_2$ is a constant. Also from observations, an object's acceleration depends on a property (which is observed to be an inherent property) termed mass. The property Mass is then defined as, $$m_2 \equiv m_1 \frac{a_1}{a_2}$$
We could define some other property, call it property $Z$, such that, $Z_2 \equiv Z_1 (\frac{a_1}{a_2})^2$. This property is not useful when compared with mass.
  • How is it evident that the definition of Mass and not property $Z$ (or any other property) is useful?
  • What is the need of defining mass when it is known that mass is the amount of matter in a substance?
The operational definition of Force sidesteps the question, "What is a Force?"
  • How does the definition of Force avoid the question?
  • Are there any operational definitions of physical quantities that tell us what physical quantities are or do these definitions only exist because they help us do physics?
BioPhysicist
  • 59,060
R004
  • 1,142
How is it evident that the definition of Mass and not property Z (or any other property) is useful?
Mass is additive in Newtonian mechanics (and approximately additive in the Newtonian limit of relativity). Z is not additive.
"Amount of matter" is not a useful definition. It doesn't define a number. It's also incorrect, since we know that a big chunk of the mass of ordinary matter comes from the kinetic energies of the quarks, via $E=mc^2$.
'The operational definition of Force sidesteps the question, "What is a Force?"' How does the definition of Force avoid the question?
It provides an operational definition, which allows us to deal with forces without even needing to supply a conceptual or dictionary definition.
Operational definitions can be interpreted in order to gain conceptual insight, but they are not themselves dictionary/conceptual definitions. Their advantage over conceptual definitions is precision.
For the first question, because we have uses for the property we term mass. If there is a usefulness for property Z, it hasn't been discovered yet, or at least I am unaware of it. There is an infinite class of properties that can be derived that way that are all semi-related to mass, by changing the function.
For your second question, it is a useful relationship; it can be used to calculate masses given accelerations, which are easier to measure for certain classes of objects (such as orbiting objects).
Adirian
  • 54
