I have read different accounts of time invariance leading to the conservation of energy, but have not encountered the specific logical explanation for it. Can someone provide it?
Time independance of a Hamiltonian describing a system (or a Lagrangian) does not always mean that the energy is conserved. For example, if you describe a system in a non-inertial frame of reference (e.g.: a rotating frame), then, even if there is time invariance (i.e.: the Hamiltonian of the system is independant of time), there will be no conservation of energy.
In classical mechanics, in the Hamiltonian formalism, the Hamiltonian of a system (the Legendre transformation of the Lagrangian in canonical moments) is the time evolution generator. In general, if the Hamiltonian $H$ (same for the Lagrangian) does not explicitly depends of the time (i.e.: $\frac{\partial H}{\partial t} = 0$) then $H$ is conserved (i.e.: $\frac{d H}{d t} = 0$). But the Hamiltonian is not always equal to the energy of a system!
In order to make sure $H$ is equal to the system's total energy, the following conditions must be met:
  1. The frame of reference's coordinates expressed in terms of the generalized coordinates (the position coordinates of the Hamiltonian) must not depend of time and,
  2. The potential must not depend of the generalized coordinates total time derivatives.
When those conditions are met, then $H=E$ and if $\frac{\partial H}{\partial t} = 0$ then $\frac{d H}{d t} = \frac{d E}{d t} = 0$ so the energy is conserved. Of course, in most cases, we have that $H=E$ but it is not in all cases. In conclusion: time invariance does not always mean energy conservation.
All this formalism is explicitely defined mathematically and the proofs of these theorems are quite cumbersome to write and they come with a few definitions. For further details, I would refer to a classical mechanics book like the Goldstein's Classical Mechanics book which is a standard reference for this matter.
fgoudra
  • 972
