I have read and heard numerous times that a vector field in nonabelian gauge theory which has gained mass through the Higgs mechanism decreases in strength exponentially with distance as it propagates. I would be thankful for a brief explanation of the approach and result and, if possible, a reference for a thorough treatment.
My attempt:
I expected to find evidence for this behavior in the massive vector boson propagator which can be written in the unitary gauge
$$ \frac{g_{\mu \nu} - k_{\mu} k_{\nu}/m^2}{k^2-m^2}. $$
I would like Fourier transform this to position space, so I integrate the following term by term
$$ \int_{-\infty}^{\infty} \frac{g_{\mu \nu} - k_{\mu} k_{\nu}/m^2}{k^2-m^2} e^{2\pi i k_{\mu}x^{\mu}} d^4k. $$
I have three types of terms to integrate:
$$ \int_{-\infty}^{\infty} \frac{1}{k^2-a^2} e^{2\pi i kx} dk $$
$$ \int_{-\infty}^{\infty} \frac{k}{k^2-a^2} e^{2\pi i kx} dk $$
$$ \int_{-\infty}^{\infty} \frac{k^2}{k^2-a^2} e^{2\pi i kx} dk $$
But I get divergences in these integrals and I am unsure where to go next.
R.C.
  • 103
Mathematica will make fairly short work of these integrals. Or they can be looked up in a field theory text book. I believe, for example, that the Fourier transform of $1/(k^2+m^2)$ is discussed in connection with scalar fields and the Klein-Gordon equation in the first few chapters of Peskin and Schroeder, at least in a Lorentzian setting.
Why the Fourier transform of this propagator is related to the Yukawa potential in the first place is a different question. If I were to try to derive it, I would calculate tree level exchange of a massive vector in field theory. Then I would try to figure out what potential in the Born approximation in non-relativistic quantum mechanics would lead to the same scattering. A slightly different answer is here.
Let's start with the first integral $$ I = \int d^4k \frac{e^{i k\cdot x}}{k^2 + m^2} \ . $$ Note I have flipped the sign of the $m^2$ term. This is because I want to do the integral in Euclidean signature. I can adapt the $k$-coordinate system so that $x$ points in the polar or "$z$''-direction. I can then break up the measure factor in spherical coordinates $$ d^4 k = k^3 dk \, \sin^2 \theta d \theta \, d \Omega_2 \ . $$ The last $d\Omega_2$ is the measure on an $S^2$ with unit radius. As nothing depends on these angles, they will integrate to give $4 \pi$. Let's focus on the $\theta$ integral. Mathematica tells us $$ \int_0^\pi e^{i k x \cos \theta} \sin^2 \theta \, d \theta = \frac{\pi}{kx} J_1(kx) \ . $$ Mathematica will also handle the final $k$-integral $$ I = \frac{4 \pi^2 m}{x} K_1(m x) \ . $$ If we expand out the Bessel-K function for large argument, we find the desired exponential behavior $$ I = e^{-m x} \left( \pi^{5/2} m^{1/2} \left(\frac{2}{x} \right)^{3/2} + O(x^{-2}) \right) \ . $$
A trick for the $k_\mu k_\nu$ integral is that it can be obtained by taking $x$ derivatives of the first integral. But this will give a similar exponentially damped behavior at large $x$.
user2309840
  • 1,490
