Say I am working on a problem where I have two generalized coordinates $q_1,q_2$ and my Lagrangian is independent of $q_1$, i.e. I have $L(\dot{q}_1,q_2,\dot{q}_2)$. Then we say that $q_1$ is a cyclic coordinate, and that the corresponding momentum $\frac{\partial L}{\partial \dot{q_1}}$ is constant.
But if I compute $\frac{\partial L}{\partial \dot{q}_1}$ in my case, it is not constant, i.e. if I take $\frac{d}{dt}\frac{\partial L}{\partial \dot{q}_1}$ it is not equal to $0$? What's going on?
Example, but I really just want to understand conceptually: Spherical pendulum with arm length $a$ $$L=\frac12 m(a^2\dot{\theta}^2+a^2\sin^2(\theta)\dot{\phi}^2)-mga(1-\cos(\theta))$$ since $\phi$ doesn't appear, we say that it is cyclic and hence corresponding generalised momentum is constant: $$p_\phi = ma^2\sin^2(\theta)\dot{\phi}$$ but $$\dot{p_\phi}=2ma^2\cos(\theta)\dot{\theta}+ma^2\sin^2(\theta)\ddot{\phi}\ne0.$$
Terry E
  • 35
The equations $\frac{\partial L}{\partial q_i}=\frac{d}{dt}\frac{\partial L}{\partial \dot q}$ define the equations of motion. They do not create quantities that are identically equal $\frac{\partial L}{\partial q_i}\equiv\frac{d}{dt}\frac{\partial L}{\partial\dot q_i}$.
In your example, $\frac{\partial L}{\partial \phi}=0$, so it creates an equation $\dot p_\phi=0$ which is not an identity $\dot p_\phi\equiv 0$. The resulting equation $$2ma^2\cos(\theta)\dot\theta+ma^2\sin^2(\theta)\ddot\phi=0$$ gives you an equation of motion. Solving for $\ddot\phi$ yields $$\ddot\phi=2\cot(\theta)\csc(\theta)\dot\theta$$
This makes sense physically. If $\theta$ isn't changing, then it's following a circular path in the horizontal plane at constant speed. $\dot\phi$ will also be rapidly changing if it's following a path near $\theta=0$ or $\theta=\pi$ and at a minimum when at $\theta=\frac{\pi}{2}$.
OP's question seems resolved by the fact that a constant of motion is a constant on-shell, i.e. modulo the equations of motion. It is not necessarily a constant off-shell, i.e. it is not necessarily identically equal to a constant.
