The equation is: $\lambda = \frac{h}{mv}$. m here means the mass of the object while moving or while stationary?
Asked
Active
Viewed 382 times
The de Broglie wavelength is given by:
$$ \lambda = \frac{h}{p} $$
where $p$ is the momentum. Under non-relativistic conditions the momentum is just:
$$ p = mv $$
which gives the equation you cited. At relativistic speeds the momentum is given by:
$$ p = \gamma mv $$
where $\gamma$ is the Lorentz factor given by:
$$ \gamma = \sqrt{1 - \frac{v^2}{c^2}} $$
In these equations $m$ is the rest mass and this is an invariant and not dependent on the speed.
John Rennie
- 367,598
