So I know that the Sun's luminosity is $3.839 \cdot 10^{26}$.
What I want is the luminosity per square meter at the Earth's surface. So this is what I have got so far:
I know the distance to the Earth from the Sun is $149.60 \cdot 10^9$ m. So imagining the Sun creates a sphere with a radius of $149.60 \cdot 10^9$ m, the surface area of that sphere would be $2.812 \cdot 10^{23} \mathrm{m}^2$. If I divide the luminosity of the Sun by that surface area, I get 1356 W/m$^2$.
Assuming this is right (if not, please correct me), is this actually the amount of Watts per square meter that would reach a solar panel on Earth under ideal conditions? I didn't account for the atmosphere of the Earth, and the amount of light it blocks - as far as I understand.
So what calculations am I missing here, and how would I go about finding what I want (that is, how many Watts per square meter hit a solar panel on Earth due to the Sun under ideal conditions)?
Thanks!
capcom
  • 165
What will be the proportion of this correct number hitting a 1 meter solar panel will depend on the atmosphere and there is a geographic dependence: clouds (albedo is on average 30% but higher the more northern the country), amount of daylight available, inclination of sun and locality ... .
In Greece the maximum in summer at noon is about 800 out of those watts.
Since the interest is for energy concerns the tables found on the internet are averaged over all these factors over a year, but one can get the relative rates all over from these maps.
Edit Here is a plot of the live measurement of solar radiation in Thessaloniki, Greece. You can see that the maximum is almost at 800watts/m^2 (power). To get the daily energy one has to integrate over the plot.
anna v
  • 236,935
That's exactly right (in the ideal case). Of course, this energy is spread out all over the EM spectrum (with some blocked by the atmosphere), and photovoltaic cells can't make much use of photons that are too low-energy (they don't excite electrons into the conduction band), and they can't fully utilize too-high-energy photons either. There are other inefficiencies too.
I once checked a new solar panel installation at my school, and saw that the ~$1\ \mathrm{m}^2$ panels were rated for (though not necessarily producing) 2 to 3 hundred watts, so there's a good check of your numbers with an actual physical installation.
