While dealing with central forces (purely using newtonian mechanics) I've came across this result: $$U_\text{eff}(r)=\frac{l^2}{2\mu r^2}+ U(r) \, .$$ I'm not at all fluent with the lagrangian formalism often used to deduce such results. I just want to know why we are getting the centrifugal potential term $l^2/(2\mu r^2)$. What does it stands for? I suspect that the term has something to do with the motion that the planets go through.
Asked
Active
Viewed 2,096 times
This term is used to basically understand the motion in two dimensions $(r,\theta)$ in terms of an effective motion in just one dimension $(r)$. The extra term just encodes the effect of the angular aspect of the orbital motion.
You can write this because angular momentum $l$ is conserved, and you can basically trade angular velocity $\dot{\theta}$ for the radial distance $r$, using $$l=mr^2\dot{\theta}$$
This allows us to write the rotational kinetic energy as, $$K_R=\frac{1}{2}mr^2\dot{\theta}^2=\frac{l^2}{2mr^2}$$ which acts as an effective, extra, potential term.
Now, you can only concentrate on how $r$ changes as the planet moves around in orbit. E.g., How the distance between the sun and the earth changes.
Sayan Mandal
- 1,016
